wierd headlight problem?? (sorta fixed)
Old Jan 27, 2008 | 07:21 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
Default wierd headlight problem?? (sorta fixed)
ok other wek my driver side headlight bulb went on my morrette's, so today changed it.... Still nothing.... checked the fuses all fine.... got the volt meter out the top spade reads 13+v the right i presume is the -ve and the left .45v.... The passenger side reads same top spade the right one again -ve and the left spade .20v.....
SO what the hell is wrong why does it not light up
Ad
Old Jan 27, 2008 | 07:42 PM
GUZZLER's Avatar
GUZZLER
not being silly but have you tried swapping the bulbs from side to side?
Old Jan 27, 2008 | 07:58 PM
adamski frst
yes all bulbs work the pass side but not driver
Old Jan 27, 2008 | 08:38 PM
Aaroncast's Avatar
Aaroncast
got to be return/or supply!!!!!!!!!-or dead lamp(bulb)
lamps easy!!!to check
returns easy give it an earth !!
trace supply back!!!!!!!---------------------done.
Old Jan 27, 2008 | 09:00 PM
adamski frst
can you explain slightly better??
Old Jan 27, 2008 | 11:01 PM
PROMETHEUS's Avatar
PROMETHEUS
Did you unplug both headlights when you done the test? A backfeed through the another bulb can throw you a mile. Check for corroded bulbs and fuses, I had an RS turbo which was trailered 100 miles all because the owner had a corroded fuse fitted, looked intact but was good for nowt. If you need more help PM me
Old Jan 27, 2008 | 11:40 PM
adamski frst
no dodgy fuses all nice clean new....
Old Jan 28, 2008 | 06:56 AM
Bullett's Avatar
Bullett
im no expert at all but i do know mk5 +6 escort suffer alot with the actual stalks causing lots of different problems.maybe worth looking into.
Old Jan 28, 2008 | 08:22 AM
Dave Henshall's Avatar
Dave Henshall
bad earth (painted ? ) onto the inner wing where the original ones earth to ..?
Old Jan 28, 2008 | 09:12 AM
fish99's Avatar
fish99
I had same trouble with mine...causing all sorts or weird and wonderful problems including buzzing relays and melting multi plugs... Got an auto sparky round and he said it was faulty earths.
Old Jan 28, 2008 | 11:23 AM
adamski frst
basically nothing has changed/ been moved this is why it has confused me
Old Jan 28, 2008 | 07:24 PM
AndyPen's Avatar
AndyPen
Have you treid simply running an extra earth wire to the battery terminal for example? If it works just run another to a solid body part - preferably out of the way and dry.
Old Jan 29, 2008 | 12:28 PM
Cossie-Lee's Avatar
Cossie-Lee
Hi had the same problem with mine going out. Checked everything, turned out it was the white plug at the light, fiddled about with it for a bit and hey-presto. it came back on.
Old Jan 29, 2008 | 06:26 PM
adamski frst
gonna be having a look see tomorrow, first port will be running a test earth, then will maybe try find a set of new stalks.... then take it from there....? i have tried to fiddle with the connections...
Old Jan 29, 2008 | 07:20 PM
krisberic's Avatar
krisberic
take the bulb out and plug the connector in, then try a peice of wire fron a good earth point on car and touch the metal outer part of the bulb and see if it lights up. This should tell you if you have bad earth to the cluster.
Old Jan 30, 2008 | 01:56 PM
adamski frst
OK been out today and its been half resolved!!! it is a bad earth somewhere!? i have for now supplied he bulb with another earth for now as i really could not find the fault wire as it goes through the loom
BUT i have lights again
Ad
Old Jan 30, 2008 | 03:27 PM
THE RADMAN's Avatar
THE RADMAN
im sure when i fitted mine that the n/side earthed direct to battery and there is a seperate earth for the o/side one,i just used one of the existing holes in the inner wing
Old Jan 30, 2008 | 04:47 PM
adamski frst
thats what i have just done but yes you are correct on the near side..
So god knows how mine's been lite till now
Old Jan 30, 2008 | 09:04 PM
THE RADMAN's Avatar
THE RADMAN
maybe your other earth ran across to the other side and joined that one?
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Kam B
Sep 24, 2015 10:40 AM
Ronnie Scott
Sep 20, 2015 10:21 PM
Cos500
Sep 16, 2015 09:50 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
