abs warning
abs warning
my escos been laid up in garage for about 3 months , wheeled it out to give it a clean up , but abs warning light and red handbrake light staying on and pedal really hard to press , its hardly moving . anyone got any ideas whats up ?
thanks stookay
thanks stookay
Originally Posted by stookay
thanks for the replies , the car been plugged into trickle charger while in garage , al check connections at abs pump 2 moro cheers
regards stookay
regards stookay
Re: abs warning
thanks stookay
thanks stookay
The Brake Valve can be found under the ABS Block (left side) on EsCos. its about 2" long. Not sure if these a still available from Ford.
thanks,
Manoj
checked the connections at abs pump they seem fine , the prime bit ive not tried , is that the sort of clicking noise that goes on slightly longer than fuel pump?
