AIRFLOW METER SMALL TURBO????
Old 29-11-2007, 05:52 PM
clutchitupson
clutchitupson's Avatar
Default AIRFLOW METER SMALL TURBO????
can you put an airflow meter on from another ford noing the part numbers are slightly different??? what difference would if make
Old 29-11-2007, 07:32 PM
Gordon1
Gordon1's Avatar
what car is it off and why would you want too
Old 29-11-2007, 08:10 PM
clutchitupson
been offered brand new one off an 98 escort but the numbers are slightly different just wanted to if it would work ok
Old 29-11-2007, 08:25 PM
Gordon1
Gordon1's Avatar
i would think not but dont know do youo need one then ??
Old 29-11-2007, 10:33 PM
sailorbob
sailorbob's Avatar
If the MAF does not have the same characteristics (voltage output per air mass flow) as the one fitted then your fuel and spark calculations will be wrong.
I doubt whether another Escort model's MAF will be anywhere near the same as the ST Escort.
Old 30-11-2007, 12:44 PM
GUZZLER
GUZZLER's Avatar
correct, i've seen a 1.8 zetec fitted with the wrong airflow meter, it didn't bring it up as a fault code but caused lots of problems.
Old 30-11-2007, 05:59 PM
clutchitupson
need one just to eliminate a problem
Old 30-11-2007, 06:48 PM
Gordon1
Gordon1's Avatar
were are you from
Old 30-11-2007, 07:58 PM
clutchitupson
were are you from
im in farnborough hampshire
Old 30-11-2007, 08:00 PM
Gordon1
Gordon1's Avatar
oh as i have one here you could try if you was not so far
Old 30-11-2007, 08:03 PM
clutchitupson
thanks mate theres a small turbo one on ebay for £60 might bite the bullet and have it as spare and see if it works
Old 01-12-2007, 02:18 AM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
i have a brnd new item paid 150 for it would sell for 100 if your stuck
Old 02-12-2007, 07:32 PM
Escort1.8si
Escort1.8si's Avatar
i have one fitted to mine from a escort 1.8si, car goes really well. But if its leaning out or anything im not sure.
3i Jim
20-11-2015 05:12 AM
Matt Baxter
16-09-2015 08:30 PM
Cosnada
27-08-2015 09:15 AM
IAN RS2k
18-08-2015 07:51 PM
Quick Reply: AIRFLOW METER SMALL TURBO????
