Best set up on an esc cos
Been reading a few threads and apart from engine mods, gearbox, diffs and brake mods, what is the best set up for an esc cos, using a standard one as a base.
Mr Rainbird reckons at least 3k+ needs to be spent to make an esc cos handle well
Beams
suspension
strut braces
etc and what are the prices etc
What setups have you lot got
I have added Mikes response off of another thread
Minimum of £3k upto what-ever you want to spend on suspension (you can spend more than that on dampers alone ).
The minimum would consist of poly bushing the car, the same suspension I have, 6° rear beam, adjustable TCAs (consisting of new Ford TCAs modded, not the cheap aftermarket ones that seem to last five minutes), plus full geometry set-up and including fitting.
Beams
suspension
strut braces
Originally Posted by Bullett
mike,whats huge money?
From: brum/shropshire drives:- frst / escort cossie
would say mike's pretty spot on there , fast road handling IMO consists of adj rear beam, adj arms, in my case black art coilovers, polybush's, strut braces and adj top mounts....
alot of people go too far like GRP A suspension and solid mounts and compression struts but 90% of the time they drive on the road so i personally feel what mike has said is spot on ...
adj rear beam, adj arms, adj top mounts
PT
im with you mate.whats worse is im work in an accessory shop.know what it is dont know how it works
Adjustable TCA's and rear beam allow you to Alter things like your Castor, camber & toe ect
Obviously with Adjustable suspention you can make it stiffer or softer depending on what the track road conditions are
Strut brace stiffen the front end up as a rear one would the rear
Polly bushes will replace the shit ones that ford did that dont last 5 minutes with heavy abuse
I would Try and Explain more but i would make a fool of myself
Im sure Mike will Clarify anything you need to know
PT
i know exactly how you feel mate.im the same.i do try to do bits myself but i normally lose my patience or break stuff.and on a cossie it cost too much if you fuck it up.and i cant afford that.
roughly my knowledge is :- changing the rear beam eliminates the toe problem cossie have as std and enables you to run the desired toe and camber ideal for your setup be it track or road!!?? the std beam ie being not adj means you cant make up for toe in (hence mike R's shims for std beam)... I also got told by my tuner the beam 'WILL' transform the car...
adj arms works on the same theory basically allows the camber to be adjusted as if you run larger rims/different tyres/suspension etc etc this will throw the std track and camber out. Therefore adj items give the the adjustment to correct this and give the cossie the required adjustment level...
adj top mounts allow camber and caster i think?? this again will give you the perfect adjustment to get the cars setup spot on as the std fitment is good will always be out slightly???
suspension speaks for itself various levels for what people want but IMO like i said most people go for ie'' bilstein grp A ***lb springs blah blah'' and then wonder why the ride like a dog on the road... those sorts of thing are made for grp A cars etc not for road going IMO theres alot more out there suitable people just buy them for the name... IMO koni's / ahmed springs are ideal for road, black art ones are better if you have 1.2k, or if your rich Ohlins 4k but unsure what ohlins would be like on the road 24/7???
as for solid mounts, poly bush's etc:- solid ones IMO are too solid for the road you will suffer huge vibration and noise now in a road car thats annnoying... hence most people stick to polybush's as there stiffer than std yet not really noisey...
think i covered quite a bit i'll prob get a load of people disagree but who cares going on what i know, i only run a chippy
Ad
strut braces will also stop the car flexing.
You when you go up a slope or curb at an angle an the car creeks, well thats the car flexing, braces will stop this loads and be more stiffer and less roll i think on track.
There are a few varients of strut braces for the front, but wouldnt know which is better or not as good.
Rear strut braces is basically a single rose jointed bar that connects to the rear struts...
Im running Gaz coilovers(cossymad spring rates) ,adjustable tca's, front and rear strut braces, fully polybushed and rear beam shims. Next plans are ava spec front tca's and compression struts, adjustable back beam and mibi frame conectors.
Coilovers £500
Shims £10 from mike
Front brace £?? was fitted to the car when i got it
Tca's £200, new set up will be more expensive but will have rebuildable ball joints and rose joints.
Rear brace £80
Looking at around £800 for a back beam for a road spec beam.
The frame connectors are from Danny B on here and think they basicaly connect suspension mounting point front to back on the car to stop flex.
Shims £10 from mike
Rear brace £80
Something people also forget is the wheel size & tyre choice. 19" prob look great but don't do much for the handling. Also fitting too stiff springs as the wheels & suspension will just bounce off the bumps in the road not absorb the shocks. When ever I change anything to do with the suspension I get the setup checked on a laser 4 wheel alignment. Worth the £30.
What Adam said is pretty much spot on . The only thing that he missed was the fact that the real problem with the standard rear beam on a Cossie is that there is a huge disparity in roll centres from front to rear that this creates. The 6° rear beam addresses this.
If you want to know more about suspension, I actually wrote a very detailed (but understandable) feature for Fast Ford on this, and it explained all the terminology as well. If you are really serious about understanding the way the suspension works on a Cosworth, then speak to Simon or Dan from Fast Ford and you will be able to buy the relevant back issue .
Originally Posted by Franco
Ade,
I drove it out of Danny's place and noticed the difference! The car felt so solid!
The best mod i did, on a level with the brakes and another purchase which remains a secret at this stage!
Some pics:
MSN if you want to know more!
Some pics:
Originally Posted by ECOS95
Do they make that much difference on an Escort ?? has anyone had it done other than on saffs ?
