4x4 cosworth re-build
Old 25-10-2007, 04:23 PM
steveo135
steveo135's Avatar
Default 4x4 cosworth re-build
just had engine re-built, got a bottom end gasket set been told not to use cork gasket use sealant any help will be great
thanks
Old 25-10-2007, 04:30 PM
ECOS95
ECOS95's Avatar
I'm sure that is what its meant to have from the factory. My ST has what looks like a sealant gasket.
Old 25-10-2007, 04:50 PM
steveo135
steveo135's Avatar
not sure as road n rally in blackpool have done the engine work, the engineer told me not too use the cork one. thanks
Old 25-10-2007, 05:03 PM
ECOS95
ECOS95's Avatar
What I ment to say is think it should be sealant not cork.
Old 25-10-2007, 06:02 PM
SortedCossie
SortedCossie's Avatar
i've only ever used sealant (good quality like locktite).
don't expect it not to leak though, i've never seen a used 4x4 that doesn't dribble a bit somewhere around the sump.
Old 25-10-2007, 06:05 PM
Kelv
Almost there!
Kelv's Avatar
as you have been told mate, Dont use the cork gasket!
Old 25-10-2007, 10:57 PM
dave cos4x4
dave cos4x4's Avatar
4x4's don't have sump gaskets.
they all use sealent.
Old 26-10-2007, 10:02 AM
steveo135
steveo135's Avatar
cheers guys
Old 26-10-2007, 02:03 PM
The DIVA
The DIVA's Avatar
I use a cometic 2wd sump gasket on them,they are made of a very tough card and you will only need a very tiny bit of sealer around where it meets the half moons....
MARKYMARKONE
20-08-2015 12:55 PM
cossie4x4
14-08-2015 06:29 PM
14-08-2015 07:29 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: 4x4 cosworth re-build
