Koni Rear Adjustment
Can someone remind me which way to turn my rear suspension to stiffen it. Also how many turns are there from sort to hard?
What set up would cause under steer? stiff rear soft front or they other way round?
Thanks,
Gav
Thanks,
Gav
right front strutts-anti clockwise to stiffen/same for rear---koni dont recommend full hardness for eveyday use((( not like the wife then!!!!----
un-bolt the rears to turn!!----------fronts req's the knob!!(ive got some of those!!)--------- e bay koni adjuster-
setting depend on how you want to drive front easy to adjust but my rears are a bitch so i keep them hard same for front-ive got big time neg camber on all 4 wheels and go around corners like the devils after me and it sticks like shit, can feel a bit hard but i like to feel the road (old skool!!) same goes for music in the car -none!! i like to hear whats going on from the engine!!
-------------------- been of help?? good-cheeRS
Thanks, fronts are easy, I do the adjuster. But its been a while since I changed the rear settings. When First fitted I stiffend the rear a bit and now want it a bit stiffer.
Thanks.
Gav
Thanks.
Gav
Here you go. As said the fronts are easy to adjust. This is the rears;
Edited to add our shocks are the 26series and only have two clicks incase you are wondering where the third one has gone.
Pete.
Pete.
truffleshuffle
10-09-2015 09:35 PM
