Coil over kits Escort Cosworth
Old 28-09-2007, 02:40 PM
joo5ty
joo5ty's Avatar
Default Coil over kits Escort Cosworth
What do you guys advise?
GAZ shocks or AVO ? or another brand?
Thanks
Old 28-09-2007, 02:51 PM
steviecossie
steviecossie's Avatar
ive got GAZ on mine
really pleased with them
Old 28-09-2007, 03:07 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
1. What are you going to use the car for?
2. Why do you "think" you NEED coil-overs?
Old 28-09-2007, 03:08 PM
Ruudsengen
Made In Norway
Ruudsengen's Avatar
I have Gaz on mine too. Have nothing bad to say about them.
Old 30-09-2007, 11:27 AM
joo5ty
joo5ty's Avatar
Well im not going to track race it, but I want to be able to buy other wheels and adjust the car so it looks perfect.
Old 30-09-2007, 08:46 PM
Mark V8
Mark V8's Avatar
Are any available with stainless bodies ?
Sure you can adjust the suspension to handle well and/or give the car a nice stance but from what I've seen they all just rust into a horrible mess after a while
Mark
Old 02-10-2007, 09:40 AM
joo5ty
joo5ty's Avatar
Mark
I have seen an advertisement in passionford that had coil overs that didnt rust, but it wasnt an AVO or GAZ coil over.
On the otherhand..can you give an estimate of when they become rusty? After a year or are you talking about 5 tot 10 years everyday use?
Old 03-10-2007, 07:14 AM
joo5ty
joo5ty's Avatar
Mark
what about this?
http://www.kwsuspensions.de/uk/30_Pr...vers/index.php
stainless steel (!)
Old 03-10-2007, 08:06 AM
Mr.Ford
Mr.Ford's Avatar
Deffo H&R
Old 03-10-2007, 08:35 AM
m-sport
m-sport's Avatar
I have GAZ on my escos and im satisfied, good handling both on street and trackdays, one problem is if you lower the car the springs are loose when you lift your car.. so if you go for GAZ make sure you get the extra small springs to mount in the top. I try find a pic on my car and show you what i mean.
/J
Old 03-10-2007, 08:46 AM
Mike Rainbird
Caraholic
These won't rust :
http://www.randbmotorsport.co.uk/sho...?ProductID=288
Old 03-10-2007, 09:24 AM
joo5ty
joo5ty's Avatar
/J
cool thanks!
Old 03-10-2007, 09:25 AM
joo5ty
joo5ty's Avatar
really?
for only 1250 pounds they are twice as expensive as an AVO or GAZ
Old 03-10-2007, 09:26 AM
joo5ty
joo5ty's Avatar
Originally Posted by Mr.Ford
Deffo H&R
Deffo 1,5 times as expensive at around 1000 pounds...or can you supply me with a good address in holland?
Old 03-10-2007, 10:43 AM
Mike Rainbird
Caraholic
Originally Posted by joo5ty
really?
They feature proper motorsport valving, so work really well on both road and track and come with the best springs money can buy. They have been exstensively tested on both the road, track and at the Nurburgring and use the best quality parts. Mine have been on my car for four years and are still going strong, with no problems with siezing adjusters etc that you get with the cheap ones.
Old 03-10-2007, 12:40 PM
Mr.Ford
Mr.Ford's Avatar
Deffo H&R
Expensive, but almost the best you can get
I've had them mounted on my previous Escort Cosworth. Superb!
www.autoshopmanders.nl can deliver them
Btw. What Escort Cosworth do you have?? Any pic's?? I saw you have you complete ERST for sale in parts???
Old 03-10-2007, 01:18 PM
Mike Rainbird
Caraholic
I would hardly call fixed bump and rebound "almost the best" .
Old 03-10-2007, 07:13 PM
cosworth3d
cosworth3d's Avatar
What would you advise then for in my case 300 bhp t25 escos with a little track action tourist rides on the ring ect ?
Old 03-10-2007, 09:29 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
ohlins if you have deep pockets! but the ring spec ones are the next best thing hay mike
Old 03-10-2007, 10:55 PM
Mr.Ford
Mr.Ford's Avatar
I have KONI (yellow) shocks and Eibach (WOLF) springs, Powerflex bushes, and a strutbrace at the front.
I'm quite happy with this Setup
Old 04-10-2007, 07:54 AM
Mike Rainbird
Caraholic
Koni's, Powerflex bushes and Ahmed's track spec springs is all you need then. I would then recommend spending some money at a later date on an adjustable rear beam.
Be aware that if you have 8" x 18" wheels and 225/40 tyres with the standard ET25 offset, you will need to "tweek" the spring cups of the dampers with a big hammer to stop them rubbing on the tyre . Fitting ET15 wheels solves this .
Old 04-10-2007, 01:58 PM
joo5ty
joo5ty's Avatar
Ah yes ok, so this is another big plus when using coil over springs...together with lowering the car to the exact level you would like it what ever wheel you use and might buy in the future...I still think coil overs are nice to have, but just go for GAZ or AVO so you wont spend too much?!
How about that?
Old 04-10-2007, 02:39 PM
Mike Rainbird
Caraholic
I think that is very poor advice, as the springs that come with the kits you have mentioned are very poorly matched and make the car handle HORRIBLY. Also the adjusters sieze after one bad winter, so it is a complete false economy in my opinion.
Old 04-10-2007, 05:29 PM
ECOS95
ECOS95's Avatar
You get what you pay for, buy cheap pay twice.
Old 04-10-2007, 05:58 PM
MATCOS
MATCOS's Avatar
Mike how hard are the Ring spec coilovers to set up, would a tuner be able to set these up for optimum handling?
Old 04-10-2007, 10:30 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
I need a set of top spring cups for my rear bilstien mag coilovers, anyone help me out asap please?
Old 05-10-2007, 06:00 AM
Mr.Ford
Mr.Ford's Avatar
How about that?
Remember...don't lower an Escort Cosworth to much! Otherwise it will cost you a lot of driveshafts and your frontbumper and exhaust don't like speedbumps anymore
I think about 25-30mm is the limit!
Old 05-10-2007, 07:20 AM
Mike Rainbird
Caraholic
Piece of proverbial!
On the road, you run them on the softest settings, and they are MORE compliant than the Konis .
On a dry track you run them on position 7/8 (of 24) on the rear and position 18-24 (of 24) on the front, dependant on the type of corners. You can soon feel how the car is reacting, as 1 click makes a huge difference. If it is a really tight track, then you may need it to be a fraction softer (depending whether you can feel the back end "hopping").
On a wet track, I would recommend running the settings at either the softest or half way between the road and the dry track settings (depending on how slippery the track is). With a wet track, you want the car to roll about a bit to transfer weight to the relevant tyres to provide grip. If it is too hard, it will just slide.
Old 05-10-2007, 01:14 PM
cosworth3d
cosworth3d's Avatar
So in my case with Azev A ET18 rims there would not be a problem with koni's
Old 05-10-2007, 01:19 PM
Kelv
Almost there!
Kelv's Avatar
cosworth3d should be easily fine mate.
had the above mentioned issues with my old Gaz, one of the fronts siezed and the other side bent the top. had to go back to gaz for them to fit new bodies to them
Old 05-10-2007, 01:58 PM
Mike Rainbird
Caraholic
You may well still have problems and will need to tweek the spring cups, as I'ms sure the AZEVs are an 8˝ rim....
Old 05-10-2007, 05:35 PM
MATCOS
MATCOS's Avatar
Why thank you for that Mr R
Old 06-10-2007, 03:31 PM
cosworth3d
cosworth3d's Avatar
That's correct 18 x 8.5j et 18 so that would mean coilovers ??
Old 06-10-2007, 06:10 PM
Kelv
Almost there!
Kelv's Avatar
cosworth3d - or tweek the spring cups as mentioned!!
Koni's and decent springs is a good suspension setup, and tweeking the spring cup is easy enough to do
Old 07-10-2007, 02:22 PM
cosworth3d
cosworth3d's Avatar
Ok koni's was my first choice can someone tell / show me what's involving to get the cup tweaked ??
Old 07-10-2007, 04:28 PM
ECOS95
ECOS95's Avatar
A big hammer, or a bad day @ work with a small hammer. lol.
Old 07-10-2007, 06:26 PM
cosworth3d
cosworth3d's Avatar
ok now you got my interest
Old 09-10-2007, 08:41 AM
Mike Rainbird
Caraholic
A big hammer - don't mis-hit, or you'll dent the wing :
Old 09-10-2007, 09:01 AM
K.Goa
K.Goa's Avatar
Did drive a 3door this summer with gaz coilovers, as Mike sais, the standard springs are badly matched to the dampers, making it a very BOUNCY ride.. springs to hard and rebound to loose.. make the car look like a BMW e30 with 60mm drop springs and standard dampers done 200k miles nodding as it goes by..
Old 10-10-2007, 02:37 AM
Arnie
Arnie's Avatar
everyone seems to be using Koni, how about bilstein? are they any good?
Quick Reply: Coil over kits Escort Cosworth
