instrumental lights not working
hi
wen i put my lights on in the dark then the lights of my instrumentals doesn't work so I can't see how much speed I drive or my turbo pressure non of the lights work
only the radio and the heating and foglicht buttons have light also the clock have light
the others don't have light even the ashtry doesn't have light
what can be the problem?????
ow btw it a europeen car --> left hand drive
cheers tom,
cheers tom,
Originally Posted by dave green
do you have side lights, if you dont it will be the light switch /wiper switch
Dave
Dave
only my instrumentals licht doesn't work
the indicotors on the instrumentals work also, like fuel, battery, biglight, handbrake,...
Originally Posted by sortedcossie.com
check that the dimmer switch hasn't come disconnected. failing that if your exterior lights work then could be a blown fuse somewhere
I will check the fusebox today!
greetz tom,
Lighting
Hi Mate, i have had the same problem with my cossie, and know how this silly problem can really get on your nerves.
I have done the following things to sort my problem out.
1. The indicator stalk provides power to the electricial system, this can fail, causing lighting faults, so i replaced this and some problems sort themselfs out.
2. The lighting system on the turbo pod disconnect the supply to this and test the system with a lamp, if your getting power to it then it can be a bad earth.
3. The cossie dash runs on elctro luminscene, not bulbs like my local ford dealer told me. Over the years the dash can break down causing the luminscene to fail, if this happens then it can be hard to track down new clocks as ford discontinued them.
There is a company in Itlay that make replacement luminscene dial for the cossie with uprated boost and increased mph, it also contains the luminscene.
The link is www.birba.com
4. Try the dimmer switch under the coloum, wire it directly in and if the clocks work then this is the problem. If they do your need a new inverter.
Im no mechanic and only doing things that i have been told to try, hope this helps you.
Regards
Gareth
Regards
Gareth
Has anyone had these above dial kits fitted? if so are they any good? wouldn't mind a new set to get rid of the slight blotches, would it be best to put a new invertor in while there out and in bits? Cheers Mark
If its not the dimmer wire come off then it's almost certainly the inverter in the back of the clocks. When this goes you loose all the gauge lighting but everything still works.
Unfortunately the inverter board is no longer available but you can make a replacement.
I have this problems
I fit birba's dial illumination but the problems continued
I fit a new inverter from birba, but it don' work it's not the same of standart parts...
So, I search a new inverter
