How many turbo-boost on your small turbo Escort??
As above:
How many turbo boost do you have on your small turbo Escort?
I've made a quick Paint-shop...
picture 1 show's the boost peak, the 2nd is the boost its holding:
Anyone an idea how many boost it is??? I was guessing:
Peak 1.6 bar, Holding 1.4 ??
Thnx
Thnx
Originally Posted by cossymad
You guess is about right. Mine hits and holds 21psi (1.5bar) and needle is right down there around bo!!
How many BHP do you have??
Not that much......
MAGNEX FULL STAINLESS EXHAUST DE-CATTED FROM TURBO
POWERTEC STAINLESS INDUCTION KIT
MULTI-LAYERED STEEL HEAD GASKET
HYBRID STAGE 4 TURBO GTI-R COMPRESSOR WHEEL, 360 BEARING
OMEX MANAGEMENT (ANTI-LAG etc) fitted 2007
OMEX CUSTOM ENGINE LOOM fitted 2007
3 BAR MAP SENSOR fitted 2007
550cc FORD FOCUS RS INJECTORS fitted 2007
FULL SAMCO BOOST HOSE KIT
FULL SAMCO WATER HOSE KIT
SAMCO ANCILLARY COOLANT KIT
BAILEY HEADER TANK
BAILEY SWIRL POT
BAILEY OIL SEPERATOR TANK
BAILEY POWER STEERING TANK
BAILEY DUMP VALVE
BD10 CAMS
PIPER FOLLOWERS
PIPER CAM BELT
60mm HKS BOOST GAUGE
DENSO IRIDIUM SPARK PLUGS
BOSCH MOTORSPORT FUEL PUMP
VIBRATECHNICS ENGINE MOUNTS
304.6 BHP @ 6129 RPM
367.4 LBFT @ 3376 RPM
I sell the pillar mounts £55
BAILEY HEADER TANK
BAILEY SWIRL POT
BAILEY DUMP VALVE
BD10 CAMS
PIPER FOLLOWERS
PIPER CAM BELT
Now it has hybrid T28 on it 21psi 303bhp / 367lbft, but it used to hit about 1.3 bar of boost on the standard turbo.
mmm...
I've still got the original turbo on it Maybe a good idea to lower the boost a bit!
How many bhp did yours have with the original turbo and 1.3 bar ???
Matt Baxter
16-09-2015 08:30 PM
