best coil over kit for an escort cosworth
hi there, whats the best coil over kit ,to go for an escort cosworth road use not with a hard ride . any advises please???????
many thanks
many thanks
i found the Gaz coilovers a little harsh for road use, even altered the rear spring poundage as the ones supplied in there kits are far to extreme!!
they are ok for a budget entry level coilover but you would be better off using Koni's wth a decent spring package if thats what your looking for.
its a shame Leda went under, but there head man is up and running again, Leda's with alot more improvements and adjustment control, just ordered my set
depends what your budget is aswell
From: brum/shropshire drives:- frst / escort cossie
Adam, but your gay and havent fitted them, yet..... so i hear!!!
Originally Posted by YBT200
hi, thanks for your help, the problem is not the budget the thing is that i don't what the ride hard !!!!
no use in having coilovers if your gonna setup the car soft.or it to be soft handling.
http://www.randbmotorsport.co.uk/shop/Details.asp?ProductID=288
As per Kelvin / Adamski's and my own car .
Originally Posted by jbrayley
Ohlins
mind you - i would aswell if i could afford them
Still waiting to see the work on your car Jamie
Originally Posted by NEIL A
Jamie you need to get some pics of your car up as by the soounds of it , its getting the best of everything FFD,Ohlins.... its like a wish list.
Originally Posted by MartinRS
while we are on the subject i have got ledas on mine but one needs rebuilding any one know who i can contact to get it sorted?
Unfortunately ALL coilover kits on EVERY Cossie need the nearside rear wing "relieving" with a fuck-off big rubber hammer, just to stop the spring from rubbing on it and squeaking. I don't know why it is just this side, so must just be down to Ford's tolerances . If you don't do this, it does nothing more than just squeak and rubs the paint off the wing / spring.
Ben,
You have the AVO Monotubes as per their Grp A Escort, but specced to the same damping rates as the old LEDAs to give a comfort / ride compromise.
Due to the fact that the rears run upside down like the Evo TM's / some motorbike forks, the damper lengths didn't translate identically, so they were a little too short and had to be sent back to be modified, hence why yours have only just been sent back following the required mods .
Several weeks after your order had been initially received, one of the guys from LEDA set up his own company and has started to make dampers to an almost identical spec as the old LEDAs and given that I wanted to help him succeed, I ordered the next couple of kits from him .
Mike, do you sell or know anyone who can sell me the rear coilover top spring cup for a set of Mag bilsiens please? As I lent them to a mate and the clown has lost them
Originally Posted by Gatecrasher
How many positions do yours do ohh well i only want soft for the road, medium for track when its raining and hard for when its Dry anyway dont i?
im sure they will cater for your needs
