Wheel offset
Old Aug 26, 2007 | 12:47 AM
Arnie's Avatar
Arnie
Default Wheel offset
Guys, I'm going to get a larger set of wheels, but what offset should it be? I want it flush with the wheel arch. any idea?
these are the one I'm planning to get, haven't decided on the size yet, 17 or 18
http://www.work-wheels.com.hk/produc...?product_id=68
or these
http://www.work-wheels.com.hk/produc...?product_id=69
Old Aug 26, 2007 | 06:41 AM
yrkesman's Avatar
yrkesman
Default Re: Wheel offset
or these
I have Compomotive MO's 18" 8"wide and they have ET15. They fit quite nicely. Altough it's much more nicer to drive with standard ET25 16" wheels, but it could be just from the smaller diameter wheels and nothing to do with the ET.
Old Aug 26, 2007 | 09:05 AM
THE RADMAN's Avatar
THE RADMAN
depends on width of wheel as to what the best off set will be, arent work wheels all 5 stud? or are you fitting 5 stud hubs?
Old Aug 27, 2007 | 08:10 AM
Arnie's Avatar
Arnie
the stud pattern and PCD can be custom made, so no problem there. I'm going to stick with 225 width tires, and want the rim to flush with the body work, but have no idea what kind of ET I'll need
Old Aug 27, 2007 | 09:27 AM
THE RADMAN's Avatar
THE RADMAN
if you are using 225 then itll be either an 8 or 8.5" wide rim i presume, rondells are 8.5 and et of 18, if for example you used an 8" rim you would need an et of 12 to get it to extend the same amount as the rondell but the inner face would be 12mm more clearance, if you go for an et higher than 18-20 you could end up with clearance issues for your brakes and shocks
Old Aug 27, 2007 | 09:39 AM
Arnie's Avatar
Arnie
I've read somewhere that the ideal offset for an escos is ET25, so not true then?
Old Aug 27, 2007 | 09:46 AM
THE RADMAN's Avatar
THE RADMAN
you could do that on an 8" rim but i thought you wanted them to stick out more??? generally go with et 15-20 and youll not be far off
Old Aug 27, 2007 | 09:57 AM
Arnie's Avatar
Arnie
Thanks
Old Aug 27, 2007 | 10:52 AM
TONY F's Avatar
TONY F
my comps are 18"-8", with an et 15
Old Aug 27, 2007 | 02:50 PM
Arnie's Avatar
Arnie
does it flush with the flare arches mate?
Old Aug 27, 2007 | 03:03 PM
yrkesman's Avatar
yrkesman
Not a good picture, but hope it helps
Old Aug 27, 2007 | 03:05 PM
Arnie's Avatar
Arnie
nice to know you are not a bufty boy
Old Aug 27, 2007 | 03:10 PM
yrkesman's Avatar
yrkesman
I do wash it sometimes but since the car is bought for to be used I don't see the point washing it all the time
Old Aug 27, 2007 | 06:11 PM
Speedy G.'s Avatar
Speedy G.
Compomotive MO 8x18 - ET15
Old Aug 27, 2007 | 09:32 PM
THE RADMAN's Avatar
THE RADMAN
did you fit the eibachs geert? it looks very low at the rear but doesnt seem to have much neg camber? maybe its just the angle of the pic
Old Aug 28, 2007 | 01:02 AM
Arnie's Avatar
Arnie
another thing, how the hell can you not get negative camber at the back when lowered?
Old Aug 28, 2007 | 06:21 AM
THE RADMAN's Avatar
THE RADMAN
you cant unless you start paying big money on adjustable rear beams
Old Aug 28, 2007 | 08:36 PM
Speedy G.'s Avatar
Speedy G.
Yes Nick, fitted your Eibachs together with new Bilstein all around.
Old Aug 28, 2007 | 10:23 PM
THE RADMAN's Avatar
THE RADMAN
looks well on them geert
Old Aug 30, 2007 | 07:43 AM
Speedy G.'s Avatar
Speedy G.
Wheels do look great but I've got something else in the pipeline.
These might come for sale in the not so distant future.
Also very happy with the springs I got of you m8. They were actually new me thinks.
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
