How do you remove the gear knob
As above,I have now managed to remove the console but I cant get the gear knob off does it pull off or twist as it doesn't seem to want to do either
From: brum/shropshire drives:- frst / escort cossie
matt 2 screws if you look inside the DIN. 2 screws where the ash tray is,1 under the window switchs. then you may or may not have the 2 fastners in the footwell push the centres in and they come out this side then you can resue them after . An i think the nob is screwed as i have a monte one which is held on with a hex bolt..
if you can't work it out after that you know what you can do
rsguy
44
29-09-2015 03:29 PM
Fudgey
17-09-2015 01:06 PM
