removing charge cooler on bt esc .nightmare please look!!!
as above have bought a big cooler today and fitting kit but need to sort out the pipe work to the charge cooler anyone know best and easiest way please may of been asked before but i cannot find it anywhere
i bought a u bend pipe samco but mounted cooler on 2 holes at front of chassie rails { was a nightmare} but the bracket that the raidiator sits on then is about 1" apart from where i need it to be must be an easier wat than this anyone make a bracket to solve this . worst job ive had to do for ages
You need the little bracket mate - you then mount the little bracket using the hole where the rad was originally mounted, and you can then use the 2 holes on the bracket to mount both the rad and cooler very easily. You'll also need the extra fitting kit to mount the cooler - you can see it all bolted up in the pic!
I got my bracket with the cooler chap - Pro-Alloy jobbie - although I'm slightly confused why you wouldn't have got the little bracket with the cooler unless it mounts in a different way.. - not that i'd know about any other makes of cooler and fitting i'm afraid
Have you done a search on here at all? - you can normally find the awnser to all queries with a little searching
