Using a 2wd Manifold ????
Post Miester !
I am thinking of using the 2wd Manifold on the Escos, will it still come up to the same point as before, with the turbo inline with the zorst ???
And is this a worthwhile conversion ??
Al..
Al..
on a 4x4 saff if you've got a mongoose fitted you have to squash the part that runs underneath the gearbox so it can come up enough to fit on the turbo if you wanna fit a 2wd manifold
Almost there!
fitting a 2wd manifold for increased flow only to restrict the exhaust system by 'squashing it'
Alex, if you do go ahead with it all you will have to do to the exhaust downpipe is have it extended by about 2" so it just raises the flange further into the engine bay to mate to the turbo, easy peasy job
hmmm i have been thinking of this as well, sounds a bit much right now, will prob use this with the external waste gate set up planed, whats the max flow / out puts for the 2wd manifolds ???
i know the 4X4 is rated @ 420 ish but i am already @ 450 on it, ( the max for the intake ?? )
I've seen a lot of exhausts that have been welded up crack or leak at the weld as the metal is quite thin.
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
caprixpack
25-09-2015 07:53 PM
