running/idling problems
Old Apr 1, 2007 | 08:50 PM
scott-cos's Avatar
scott-cos
Default running/idling problems
hi everyone my small turbo esc cos isnt running great. well not running atall now.
was out in it yesterday and everything was fine. went out this morning and it was misfiring on idle. left it like this for a few mins and it cleared up. went to drive away and it cut out. tried to start and it wouldnt. it just kept winding over. removed the plugs and they were covered in carbon. changed them over and tried again with no luck. plugs just got soaked in fuel. i no its getting spark and fuel.
any help would be good.
Old Apr 2, 2007 | 07:43 AM
Fisrt off listen for fuel pump prime, if it does not wiggle the Crank Pos connector and try again.
Old Apr 2, 2007 | 08:29 AM
Mr.Ford's Avatar
Mr.Ford
maybe the dis-bobine is not good, or sometimes the cables to the bobine are worn
Old Apr 2, 2007 | 09:19 AM
S3an's Avatar
S3an
sounds like maybe a air leak or the map sensor is buggered
Old Apr 2, 2007 | 11:06 AM
scott-cos's Avatar
scott-cos
fuel pump is running. does the small turbo cos have the same ect sensor problem as the big turbo
Old Apr 2, 2007 | 03:12 PM
CTS is the same, afaik.
Pump running connection with CPS is ok.
Old Apr 4, 2007 | 05:25 PM
scott-cos's Avatar
scott-cos
ok i got my esc cos running now. cleaned up the plugs again and tried it. started up first time and running perfect now. still not sure what caused it.
Old Apr 4, 2007 | 09:44 PM
AndyBrew's Avatar
AndyBrew
is it chipped??? the chips in EECIV are notorious for being tempremental if it plays up again try whipping the chip out and see if it cures it
Old Apr 5, 2007 | 08:53 AM
scott-cos's Avatar
scott-cos
yeah it is chipped. i thought this might be the problem. ill leave it and see how it goes.
Old Apr 5, 2007 | 11:45 AM
AndyBrew's Avatar
AndyBrew
could be that then especially if its just plugged in with a bit of tape over the end. This happened to mine, everything was running perfectly and then one day it just cut out on me and died
after a trip home on the AA flatbed somebody suggested taking the chip out which I did and then all was well I think TurboSystems ended up putting a whole new case in which appears to of resolved the problem
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
