Sensor question
Old Mar 5, 2007 | 07:42 PM
Stoo's Avatar
Stoo
Default Sensor question
I think my coolant temp sensor is possibly faulty. It's not overheating or anything like that but i'd rather just change it.
It's the blue one, right? ECT?
Just wanted to check..
Thanks
Old Mar 5, 2007 | 09:02 PM
THE RADMAN's Avatar
THE RADMAN
yep
Old Mar 5, 2007 | 09:10 PM
Stoo's Avatar
Stoo
Thank you very much! Just near the oil filter...?
Old Mar 5, 2007 | 09:14 PM
rapidcossie's Avatar
rapidcossie
if this was faulty Stoo it would usually cut out as the engine heats up..
basically the sensor gets confused and massivley over fuels the car.
Old Mar 5, 2007 | 09:26 PM
Stoo's Avatar
Stoo
Hmmmm
Was just something Andy mentioned, said it wasn't quite right. Just assumed it ment it might be running a bit hot but reading okay on the gauge.
Ahhhhhhhrg fucking cossies I'll just wait untill it goes wrong instead of thinking and worrying about it
Old Mar 7, 2007 | 12:26 AM
Arnie's Avatar
Arnie
Originally Posted by Stoo
Hmmmm
I may be wrong but the ECT doesn't send signal to the temp gauge, it's just signal to the ECU. like rapidcossie said, if the ECT dies, it overfuels the car hence black smoke out the exhaust, but the temp gauge should still read normal.
Old Mar 7, 2007 | 06:36 AM
ECT signals the ECM and has nothing at all to do with guage reading.
When I replaced my ECT engine ran perfect 99% of the time but chronically overfuelled, and would foul the plugs if left idling for more than a few minutes, started and ran perfect though.
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
