Proper pissed off
Proper pissed off
Took my stage 3 Escos to Motorscope a few weeks ago, to check the fuel and boost. No problems but just to be on the safe side as I had just fitted a rs500 intercooler and it looked like I had gained extra boost. Anyway the guy had it for hours messing on with it because it was only peaking 20 psi instead of up to 28psi anyway on the way home and ever since the back box keeps poping when I touch the accelerator (over fueling?)anyway I've only done a couple of hundred miles since, and now it wont start when it does it runs like a proper bag of shite and if you take your foot off the accelerator it cuts out any ideas whats wrong I've changed the plugs which I had just replaced and there black.
Wish I had just made the effort and gone back to MSD
<--- real tears
<--- real tears
sounds like a air leak or burst pipe to me, i would just check round all the pipes and also take a look at the map sensor to make sure the little lug hasnt snapped off it(very common)
Originally Posted by milkman
Ok mate cheers, so where is the map sensor?
try swaping the map sensor for another one, changing the engine temp sensor (the blue one) or failing that a specialist like MSD that have the parts in stock to diagnose AND repair the fault.
steve
steve
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
