Rear Trailing arm specs
Novice
Does any one know the correct settings, ( angles, lengths, heights ) for the rear trailing arms on an Escort. One of mine is bent to the extent that I have 5 degrees of neg camber and about 4mm of toe in. Since I'm in Oz, I'm hoping to avoid the freight cost of a new one, by having mine straightened and gusseted. Need to find out some measurements so I can tell the place that might be able to do it, what it needs to be. It wont be in the car when being repaired, so the wheel alignment settings probably wont be of much use to them.
ruffles mate. you still having dramas with your rear suspension send me an e mail and i will measure all the sizes you want , make up a sort of diagram of the trailing arms and A frame and the measurments you need, but i am in work till the 30th and wont be able to get them till then, i have a mate here in perth WA who has a lot of spare parts for escos,s and i am sure between us we can sort something out. every time i go tto his lock up i am like a kid in a candy shop. I have had a sig done of my escos, and here is a pic with the new wheels i want on it(photoshopped) and lowwered a bit.
also putting an RS 500 intercooler on it at the mo.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Tony W
09-09-2015 12:08 PM
