Rear Diffs
Old Oct 3, 2006 | 02:50 PM
Rippers's Avatar
Rippers
Monte Geek
Default Rear Diffs
Prob been covered loads but I couldn't find anything relevent on search.. Whats involved in changing the rear diff and how hard is it?
Old Oct 3, 2006 | 04:16 PM
THE RADMAN's Avatar
THE RADMAN
only about 4-5 bolts, and the rear d/shaft and prop bolts to remove paul but its very heavy,so make sure you have a jack underneath to take the weight
Old Oct 3, 2006 | 04:26 PM
july1's Avatar
july1
A m8 did it on track last week-end!
took about half an hour but as Radman says the joepadise (not sur how U spell that!) may be on the bolts...
Old Oct 3, 2006 | 05:39 PM
Rippers's Avatar
Rippers
Monte Geek
Cool as I just won a 3.9 ratio diff on ebay
Just gotta sort out a step off gear
Old Oct 3, 2006 | 07:35 PM
MONSTER's Avatar
MONSTER
Isn't there a quick fix ref the step off gears Paul, something along the lines of shortening the hy-vo chain, or summat like that
Search for the post by Yum re his new diff, it sort of turned into a bitch fight but there was some good info there
Old Oct 3, 2006 | 09:18 PM
markk's Avatar
markk
you will need a pair of step off gears and a shorter chain to match the 3.9 rear.
Old Oct 3, 2006 | 09:47 PM
Rippers's Avatar
Rippers
Monte Geek
I believe A1 Rallysport do all the bits tbh I'll prob take to them to get the lot done
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Fezman1
Sep 7, 2015 09:34 PM
