Rear springs
Rear springs
How the hell do you get the rear springs off coz the huge bump stops are in the way.
I dropped the rear arm and they still wont come out
undo the rear drive shafts at the outer end,undo bolt in the brake line t piece at rear of car and gently lower the arm,and brakelines, obviously mind you dont kink the brakelines dont try and force it with the d/shafts connected or you will damage the outer casings and make them oval shaped
remove bottom shockie bolt, pull arm down as far as brake pipes will let you,push off rubber bump stop, spring compressors then pull spring out from side of car
truffleshuffle
10-09-2015 09:35 PM
Adam Graham
06-09-2015 06:04 AM
