Spark plugs again........
Old 27-09-2006, 01:02 PM
  #41
Andreas
Andreas's Avatar
Stu, how come the IK31 is recommended, aint that much colder than the 071? Im running K24 right now and if im not mistaken the 071 is similar to denso heat range 27?
Mike, is it just the PP plugs that are discontinued or also the 071s?
Old 27-09-2006, 01:19 PM
  #42
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Stu,
My dealer also has stock of PP8s at the moment, but these are no longer listed on their computer (he had to look up the details on an old microfiche to get the finis code to check to see if they had any in stock ), only the PP11s which are now listed for both cars, so if I was you and you want some, I would get as many as you can now before that does become the case.
What are the PP11s rated to in your opinion?
Andreas,
If it had been 071s, don't you think I would have mentioned that?
Old 27-09-2006, 01:54 PM
  #43
S1rst
S1rst's Avatar
Right i ordered some pp8's, went down to collect them and they were denso plugs in a AGPR12PP8 box. Not sure if these will be ok for me or not.
Old 27-09-2006, 01:58 PM
  #44
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Havent actually seen a PP11 mike but i expect its the same as the 12PP8 with a 1.1mm plug gap, so around 300bhp.
Old 27-09-2006, 02:01 PM
  #45
Mike Rainbird
Caraholic
How come you're not sure, when it CLEARLY says on the previous page that they are ?
Old 27-09-2006, 03:40 PM
  #46
S1rst
S1rst's Avatar
No mate what i meant was how come the denso came in the pp8 box. It had a different number on it so thats why i wasnt sure, as ive been told to get nothing but motorcraft. So it seems denso have replaced the motorcraft pp8's as said above.
Old 27-09-2006, 03:50 PM
  #47
Mike Rainbird
Caraholic
Ah, I see. I've just opened up my box of PP8s and they say same - Denso PK20PR-P8, I assume that Denso make them under license for Ford. I'm sure Stu can clarify?
Old 27-09-2006, 04:16 PM
  #48
Thats correct and they always have done.
Old 27-09-2006, 04:18 PM
  #49
Mike Rainbird
Caraholic
Job jobbed .
Old 27-09-2006, 07:31 PM
  #50
Rene
Rene's Avatar
cheers mike (?)
Old 28-09-2006, 06:38 AM
  #51
lamar69er
lamar69er's Avatar
Just ordered a set of IK31's through work, only £22! loads off the retail price so well chuffed!
What gap should I run on these?
Im running around 350bhp on P8 ECU.
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
Brickhouse
14
03-10-2015 07:28 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: Spark plugs again........
