clutch ratchet
what do you need to remove to do it...? how long does it take,,,
im thinking of doing mine as a mater of course before it snaps as its still the original one and it getting quite stiff
At about an hours labour i think ill do it myself then. I should have it done in about 5 hours then!!
Anyone know how much the ratchet and the cable cost then? I assume its a dealer part?
i got my new quadrant springs and clips in my draw at work see it every morning when i go in and it depresses the shit out of me knowing its going to be a ass to do wil be getting my box reconned and buying a new clutch so it will be done when all that is ready,cant wait to be able to change gear,my 1st to 2nd are a bitch atm
Wasnt expecting it to be that cheap!!!
Im not 100% sure it is my rachet or cable to be honest. Most of the time my gear changes are perfect. Its just sometimes i can feel my clutch pedal stiffen slightly and its harder to get in gear, but if i release the pedal, it clicks once, then its back to normal again.
Does this sound like it is the ratchet???
Cheers.
Cheers.
might be the cable thats stretched
the best advice is that (this is on a sierra don't know what the escos is like) you just drop the steering column by undoing the 2 nuts that hold it place
that way you get more space to play with
there will be 4 bolts holding it in place if it's like the sierra, 3 that also secure the abs pump stuff and one little fooker right above the column with a big fat washer on it
spin it over the top of the column and out it comes, easy to do on a workbench/in a vice
