Fuel consumption
Fuel consumption
What sort of miles to peeps get from a stage 3 cos? I dont think mine is very good i am getting about 90 miles per £15 of fuel is that average? That is from the 1/2 mark down to the 1/4 mark on the gauge. I know its how you drive them as well but that is with normal driving.
The only way to accuratly calculate your mpg is to fill the tank then do 100 miles or so, for example, then fill it up again and work it out. Ive never done it in the escort but it doesnt seem that bad at all on fuel.
Originally Posted by silky16v
Closed loop Lambda is the way forward from MSD
I get over 300 miles 2 a full tank and on motorway about 30mpg+
if u got a pectal board in there it won't be using the lambda
Get on That!
as the escos P8 ecu has lambda control as standard but if u fit a pectal and or chip it normally doesn't use the lamdba
I'm running 330BHP on light blues, and my average is 24.27 mpg over 80 fill ups, with a max of 28.27 mpg and a min of 16.34 mpg. I track my fuel consumption accuratly in a spreadsheet.
