fuel sender???
fuel sender???
ok right me thinks me sender be fooked just fitted a new 023 with mike-r fitting kit and when i plant my foot the sender goes from say 1/4 to in the red surely thats not right Also when driving normally it goes up and down , i used a different pump sender to the one that was fitted b4 so i think this one is faulty/playing up can someone just reasure me this isn't normal
Ad
Ad
Guessing because I don't know the kit; Did you keep the baffle when you fitted the kit, losing this would allow excessive fuel surge that would cause this. Also, did you 'index' the sender's position to be operating at 90 degrees from the front/rear axis of the car in order to minimise the effects of fuel surge?
