escort wiring issue
escort wiring issue
putting i new loom as deiscoverd that old on has realy bad conections etc not in very good condition however have opted for a pectel type its a s-tag loom seam to be ok but having a few probs with the extras that im putting in ie coil pack water inject etc it also says 2wd on it will this be ok for the 4x4 cossie
reason why i ask is that it has some wires in the plug that i need ie pin 12 water injection pin 14 antilag and pins 26 have been taken up for the coil pack was told there pin 9 and 26??? (but also has a plug for it saying ALS bost control near ECU)????my qestion being is this right for my set up or have i got a wrong loom
its also got the rings for the old disstributer and not coil pack???
any info pls as im mising all this good weather!!!thanks all
just been told the pin outs from a mate but ithinks he wrong!!
pin 14 anti lag
pin 20-12 water injection
pins6-21 for coil pack or 26 he thinks
it a P8 ecu the same as the L8 layout so why have i got these other pins full as my new looms all light purpl wires ????pls help
pin 14 anti lag
1 Post
if your using pectel software in the P8,
the pins for the coilpack are: common pin 24, them amp 1 to pin 25 and amp 2 to pin 26.
pin 21 is the aircon input,
pretty sure pin 14 is antilag,
not sure on the WI though...
Cameron
14
09-08-2015 06:28 AM
