what ACT's are you running???
just a quiery really got my act guage on a week or 2 back and i seem to be runnign between 23deg-26deg normal driving, in traffic obviously goes up... just curious really
ok then u fruit!!!! yesterday what ever the heat was say 18-23!!!! at about 50-70mph using 4th+5th gear mostly. I got as mentioned above cant be anymore precise than that i forgot to take a pencil and paper and jot the temps down every 5 mins like u
altho i am using A+H fabrication coolers
Almost there!
on cool evenings and cruising calmly at around 40mph with no need for turbo can see temps in the range of 3 - 8 degrees.
average cruising temps at 70mph this time of year are sitting around 20 - 22 degrees.
over the past few days whilst travelling to/from lemans with steady cruising at 90mph, and ambient temps of 35 was still showing 23ish degrees inlet, but under hard acceleration out there at 36psi was creeping my inlet temps up to approx 34degrees. (but that was full load all the way thru 4th and 5th until hitting limiter in 5th!!)
if that helps atall!!
Caraholic
well i did 70mph in 4th for a while and came out with 22-23deg so thats not exactly what you wanted mike but best i can do on private roads
DixieTheKid
11
06-06-2020 11:20 AM
Eigdoog
13-09-2015 05:46 AM
