ESC COS LOWER REAR SPOILER
Has anyone else had any issues with their lower rear spoiler having small bubbles under the paint, had mine painted twice now for the same problem.......Is there any solution ???
When i had mine painted first time the spray shop thought it may be down to the oven, so they let it air dry second time round.....still came back. Must something to do with the spoiler material....?
Not much point in having it painted then untill it gets bad.
it's air pockets in the spoiler which expand with heat, usually show up in hot weather or when the spoiler has been painted & baked in oven, not sure what you can do to solve the problem though
as said my lower one has it here and there, the upper in 1 place too..
but as said if GOOD primer is used when rubbed back and resprayed it should not come back
I have a mint lower spoiler for sale with NO paint reaction whatsoever..and i mean.. whatsoever! completley fine
so will be fine when resprayed your colour or a bonus if yours is red!
also have the upper aswell
PM me if you are interested
mind did have it bad, my cusin is a painter, when mine went for engine build in 2005 it was away for about 4 month, he had it befor it went, and it didn't come back till i had the engine run in nearly 6 month, he said he had primed it and baked it in with other jobs about 35 times befor it stopped reacting then he "gel coated" it and its not come back yet, i said i could send him some more to do, he said "dont bother"
you guys ..use the opertunity to get a WRC rear wingi dont have troubles with whose bubbles at all
just kidding with you all
they need stripping back completely, all the dodgy bits need drilling out (its foam inside) then fibreglass the holes, then rub down and a good flexible filler.
I did mine over a year ago and before I did it, they bubbles were horendous, REALLY bad...
now, its perfect still
chris m1
07-09-2015 08:02 PM
Adam Graham
06-09-2015 06:04 AM
