Finis Code for steering part (Damo)
Get on That!
hi i need the ford finis code for the FLEXIBLE COUPLING between the rack and steering column the shaft with 2 UJ's at either end and is held in by pinch bolts
I've been to ford and all they seem to keep giving me is the 1 for a 4x4 saph which is different design as it shows a rubber donut which i know the escos doesn't have as it has UJ at both ends.
thanks
thanks
Im possitve ive got a new in my garage witht he code still on it, if damo doesnt beat me to it i'll get the code for you
dont actually need it to be fair im just slowing buying and replacing things that im worried wont be available soon, so unless my car sells soon then i'll just put it on, if not you can have it for cheap
Be prepared to have your arse slapped on the price mate...
I bought a new old stock item from ATM (via EBay), cant remember how much but a damn site cheaper then Ford
TBH I dont see why a 4B saph one will be any different apart from the fact the rubber bush section may be at the other end..
Get on That!
rite i have 1 off my 4x4 1993 K reg saph which looks exactly the same as the escos item will measure them up and see if they are the same
It must have only been the early 4x4 saph that where different (rubber bush) cause my saph 1 looks exactly the same
But still need Finis code just incase it ain't
155lee
06-09-2016 11:10 AM
