cossie clocks, dimmed lighting, help?
the clocks on my cossie are very dim, the adjuster is on full brightness.
the banana pod clocks are dim too.
the speedo is the lightest bit, is there anything to replace or is this
just what happens over time, my mates cossie has very bright clocks
it has done more miles and is an older car so i dont know why mine
are like this
cheeRs
are like this
cheeRs
Formerly COSSIE_LEE
I had the same problem: https://passionford.com/forum/viewto...light=#1867744
see here also: https://passionford.com/forum/viewto...light=#2358740
Cant get the invertor from Fords though, and there are two versions!
Got mine from someone off here so just ask around.
AJC
https://passionford.com/forum/viewto...asc&highlight=
This is the thread where you asked about it for your mate ...![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
As Lee said though cant get them any longer...
Monte Geek
One thing that might make a slight difference, I noticed I couldn't see my oddometer reading at night and assumed because of the way they light up you couldn't see them.. untill I went in Franco's one which was lite up! So taking the dash surround there is a bulb aswell and since fitting it is a bit brighter
If ford have stopped doing the inverters you should be able to use one from another supplier.
Halfords sell EL inverters for their neon EL range of stuff. They're only a fiver and with a bit of modificiation should run a set of cossie EL clocks no problem.
On here to much!!
HI DOES ANYONE KNOW IF THE INVERTOR CONTROLS THE DIMMER? MY CLOCKS KEEP DOING THE ON-OFF ANOYING THING. THEY SOMETIMES COME BACK ON IF YOU MOVE THE DIMMER. IS THIS THE SAME PROBLEM AS THE NACKERED INVERTOR? THANKS ( PITCH BLACK DRIVER)
steve
On here to much!!
the youth
THANKS MATE, I KNOW EVERYONE HAS SAID YOU CANT BUY THEM FROM FORD ANYMORE, IS THERE ANYWHERE THAT DOES ONE THATS THE SAME AND HOW HARD OF A JOB IS IT TO DO? CHEERS MARK.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
