pillar pods.
Almost there!
pillar pods.
is there any companys out there that can supply a twin pillar pod but with the lower pod in the larger 63mm and the upper one in 52mm?
may be requesting to much but im also restricted in the height in which the top pod can go to due to the roll cage being in the way.
would this be a specially made item, and Damo if you read this... would it be something you would be able to make and re-texture for me?
3dr cossie
21
20-11-2015 05:00 PM
