Missfire on Boost
#42
rstoughy
Mate do what Damo said, mine did exactly the same! when you check the meter readings off the ECU it was telling us that the air temp sensor was failing.
Had Me, Gadget, Mark & Ahmed at Grove miffed.............Till ahmed was fooking about with the loom and Mark glanced over to see the ECU module program on his laptop going crazy!
Been fine ever since!
I'll bet a tenner with you its that!
#43
Franco & Damo
Just spoke to my local ex Ford electrician so he will pop round on Monday and have a butchers at it for me
He has also said that these are likely to be the problem
Downside is i need to drive from Aberdeen to Cumbria this weekend off boost
#44
Originally Posted by rstoughy
Franco & Damo
#46
Originally Posted by lamar69er
my fault on boost turned out to be the boost solonoid thingy... (amal valve) with it dissconected the car boosts up fine! there £130 from Woodford thou, and not available from ford! Im going to get a boost controller or air to air injectors instead, unless anyones got one floating about for sale?
#47
Hi
mine did the same things after rebuild, changing all the sensores, plugs, fuel pump,......
but only the fuse box was the problem
on high boost i had only 6- 7V on my coil with the old one!
MAX
MAX
#48
Checked that live feed to the ECU tonight so it came back with a reading of 13.65v so that seems to be ok.
while i was in about the ECU i thought id check and see what chip the car was running.
Has a GGRL2V8P8 Guessing that is a GGR Level 2 version 8?
Any ideas what this should be power wise? i thought around the 280 mark
Franco
The bodge shall take place on Sat
Franco
#49
From: brum/shropshire drives:- frst / escort cossie
have you checked your lambda sensor mate?? as said my car is off to the bloke up the road first thing in the morning to be plugged in!!! hopeing its something simple
#51
bloke put it on mate and said the eprom was playing up or something to that extent??? so he said it could be the chip, yet i removed it tonight and it still did the same so i am unsure what it could be, next is to do what damo suggested about the soldering of the wires, and also i am going to order a lambda sensor as it works best when thats unplugged so that still maybe my problem...
so not much progress from me!!!
#52
I have a guy coming round next week to get my loom done for me as i wouldnt win any prize's for my soldering hopefully it will sort it out
#53
Ok fingers crossed i might have found the problem
Removed the rear bumper to check the pump wiring as it was all showing good up the front end. What i found was a very very corrodid connection. Tried to pull it apart slightly so that i could get the meter probes on and it fell apart in my hands
Stuck it back together and fired up the car and am getting just over 12V ish on the pump side of the connection.
I have had to cut around 1ft of cable back on the earth side to find good clean cable so i will solder in some fresh ones tomorrow night and see how it is after that.
I also had the Auto Spark round so multi plugs on the inner wing will be no more next week
Couple of pics
Couple of pics
#54
strange how some of these cars have really crap wiring and some dont,did my pump last week and the wiring/connections are virtually as good as the day they were fitted,hope it sorts it out for you
#55
Funny how all the other wiring on the car is perfect. Someone has been there before though as loads of insulating tape wraped round everything
#56
You were lucky if that is the cause of missfire, as THAT is prime culprit for a meltdown mate!!
Funnily enough mine were as clean as a whistle to...... !!
They are no more now though, gone to the wiring bin in the sky
strange how some of these cars have really crap wiring and some dont,did my pump last week and the wiring/connections are virtually as good as the day they were fitted,:
#57
It just where the wiring sits though tucked up behind bumper subjected to all the elements
Remember to run a fresh earth wire to somewhere in the boot u don't need to have it connected to the original earth loom
or use both the original and a fresh earth wire u should find once you rewired it you should get a voltage reading above 13v if not u need to run yaself a seperate feed from battery and a relay setup
just outta interest has the car got an uprated pump fitted or not?
#58
silky16v
Going to run a couple of fresh wires tonight and see what happens
Have a new 023 pump going in anyway
Nice to meet you on Sunday
#59
Ok update,
Soldered in some wires tonight and got a reading of 12.7v. Better than it was but still down on what everyone has been saying.
Took the car for a blast and the missfire is still there
Once my new pump & filter arrives i will run a fresh wire from the Batt and fit a relay.
oh well the hunt goes on, loom multi plugs next and then we are looking at changing out the chip.
#60
Got the car up in the air tonight and soaked all the tank strap bolts with Duck Oil ready for removing over the weekend.
Found this from the pump to the filter, looks like someone has been in here before as well.
Whats the bets i find an uprated pump in there?
#62
Originally Posted by july1
What's the bet that your fuel filter needs to bet changed... a high flow fuel pump is useless if the fuel can't go through the filter
As i have had the car for less than 1yr i'm finding things all the time
#64
Good!
When you have fueling prob the filter is one of the first thing to change if you don't know how old he is. Everybody start to think electrical or mecanical when sometimes it's quite simple
#65
july1
Its amazing that people will always replace plugs, Eng oil / filter ect but leave things like the fuel filter Dont think i've ever bought a cossie which has had a new one fitted
#67
Damo,
I have purchased a 023 pump so i will fit that anyway so i dont need to go in there again
Dropped the tank and filter out over the weekend and drained the fuel.
Found that the car already has a 033 fitted has some sort of foam wraped around it but it fell apart once i tried to remove it. Im guessing its only there for noise???
New parts should arrive today / tomorrow so i will get it put back together and see what happens. Hopefully i have found my problem looking at the filter.
Filter has not been changed for a long long time
Tank out and drained
033 pump removed
033 pump removed
#71
You know what you gotta do
Just waiting for the sparkie to get back in touch. He has been busy this week so as it was a casher i was put to the back of the que
#75
Originally Posted by Franco
Right so let me get this right?!?! You've removed the plug completely and they now reside in the boot?
#76
Capiche?
#77
Capiche?
#80
PMSL @ you two
Franco
Reason i had to cut so much wire out was that the earth was black, cut it back a couple of inches at a time untill i found clean wire. That just so happened to be inside the car so i just trimmed the live to the same place and ran in 2 fresh wires the same length job done.
Franco
