Heat from exhaust downpipe
Ive recently fitted a power engineering stainless exhaust to my small turbo cos but have noticed that its starting to burn through the back of my heatshield. Is it ok if I use some exhaust wrap on the downpipe, do you think that will cure the problem?
its shoudn't burn through, have you got the bottom bracket, this keeps the heatshield well away from the downpipe. they normally burn through when their touching, rubbing the downpipe which glows yellow after afew mins of boosting
Cahzz - Yes its got the bottom bracket and it was fine with the standard exhaust. Do you think exhaust wrap would do the trick as ive got a brand new heat shield to go on and I don't want to melt it!
intresting, theirs alot of people running large dia exhaust systems with standard heat shield, no-one else seems to be pointing this issue out, the only thing with heat wrap is that it the heat has to go somewhere, and usually it will just transfer further down the exhaust, not good where the exhaust is already in a tight area like the escos
it depends on how well made the downpipe is,some systems have a slightly tighter bend from the turbo and give a little more clearance,others arent quite as tight and combined with the bigger diam pipe end up touching the h/shield,when i had a mongoose on one of mine it did the same
I dont have an issue
There are two schools of thought on the heat wrao thing, some say it damages the turbo/exhaust housing as excessive heat builds up internally, where its kept inside the exhaust
