plenum spacers?????
Old Apr 4, 2006 | 09:39 PM
esccossie666's Avatar
esccossie666
Default plenum spacers?????
has anyone used one?are they worth fitting?
Old Apr 4, 2006 | 11:18 PM
NEIL A's Avatar
NEIL A
I have a 14mm spacer fitted to my car and didnt notice much diffrence. There was a post up about these in GENERAL section the other day think it was Bosch Man that started it, some goood points for and against in it.
Old Apr 5, 2006 | 08:33 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The restriction is in the elbow, you would see more improvement by fitting an EECIV plenum, which has a better designed (higher flow) version.
Old Apr 5, 2006 | 08:38 PM
esccossie666
where could i get one, and are they a straight forward fit?
Old Apr 5, 2006 | 09:40 PM
NEIL A's Avatar
NEIL A
A spacer or EECIV (small turbo) plenum?
Old Apr 5, 2006 | 09:54 PM
esccossie666
small turbo plenum and are they a straight swap?
Old Apr 5, 2006 | 10:04 PM
JHS's Avatar
JHS
Or modify your current plenum... Cut the thight "elbow" open, and weld on a bigger metal plate, and there you go, better flowing plenum the Jenspeed way
Old Apr 5, 2006 | 10:28 PM
NEIL A's Avatar
NEIL A
Yes sure the plenum is a direct fit only thing im not sure of is if the iscv wiring/plug is diffrent?
Old Apr 5, 2006 | 10:31 PM
esccossie666
could i use my old throttle body?
Old Apr 6, 2006 | 07:49 AM
Mike Rainbird
Caraholic
Yes, just neds minor mods. I run a 4x4 TB on an EECIV plenum.
Old Apr 6, 2006 | 09:03 PM
esccossie666
better get looking for one then
Old Jun 5, 2006 | 07:40 PM
sygjim's Avatar
sygjim
Do you have more details on mods to do ???
Old Jun 5, 2006 | 10:20 PM
Kelv's Avatar
Kelv
Almost there!
Exactly as mine, just needed to fettle the holes thru the throttle body to make it line up perfectly with the plenum, and the top of the 4x4 TPS gets a tad close to the underside of the plenum aswell, but easily rectified!
Old Jun 6, 2006 | 06:28 AM
sygjim's Avatar
sygjim
thanks
Old Jun 15, 2006 | 02:06 PM
sygjim's Avatar
sygjim
do you have some pics
Old Jun 16, 2006 | 01:33 PM
JanDK's Avatar
JanDK
Hi.. any pics maybe??
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
