Compression struts
Old Mar 28, 2006 | 03:32 PM
JHS's Avatar
JHS
Default Compression struts
Does anyone other than Burton sell these...?
Anyone with good or bad experience with these struts?
Old Mar 28, 2006 | 03:47 PM
ian sibbert's Avatar
ian sibbert
Compbrake do them.
http://www.compbrake.co.uk/TECHNICAL_COMPRESSION.HTM
HTH
Old Mar 30, 2006 | 06:18 PM
NUTS RuS's Avatar
NUTS RuS
Compbrake are a bolt on kit, so no welding required
Old Mar 30, 2006 | 06:28 PM
Leecossie1's Avatar
Leecossie1
Can you get this bolt on kit for a Mk1 Escort????
Old Mar 30, 2006 | 06:49 PM
NUTS RuS's Avatar
NUTS RuS
Not from Compbrake - they need to be welded.
Suppose theoretically you could just weld a captive nut onto a plate on the inside and have the outside bit then just bolted on ... but what would be the point in that ?
Old Mar 31, 2006 | 06:02 PM
Mr C's Avatar
Mr C
Compbrake and ZooMotorsport
Old Apr 9, 2006 | 11:26 AM
cos jon's Avatar
cos jon
Sounding stupid here, but what are the benefits to fitting these ??
Old Apr 9, 2006 | 11:38 AM
dojj's Avatar
dojj
Resident Wrestling Legend
i got mine from rally design
they let you play with the position of the wheel front and back in the arch as viewed from the side
best way to get fully adjustable suspension though is to go the whole hog and get adjustable tca's and coilovers with adjustable top mounts and a relocated arb
then you can have the wheel wherever you want to put it but it's a lot of grief unless you are going to go on the track all the time
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
