Heres one for ya
solenoid-canister purge-
can anyboby tell me what this does
its placed just by the map sensor the reason why mine is making a clicking noise and you can feel it when you hold it
ive checked the canister purge hoses are all conected
its bugging me why its clicking when the car slightly reves above idle
thanks in advance
thanks in advance
nope,not sure on that one.
Car still drives fine its only when you got bonnet up and you rev just a bit higher than idle you can hear it clicking
Going to GS motor sport soon ill get him to check it out
Id just like to no what it is and what it does
this unit draws fuel fumes off the manifold and tank and stores them in carbon canister, purge valves then run to vent the canister and put the fumes back into the engine as fumes are not allowed to escape to atmosphere anymore
Do you know why its making a clicking noise
Originally Posted by Damo V
Its clicking because its a solonoid
I dont have ont anymore
What have you taken your one off the car
Because im not sure of the last bit of your post (ont)
fiesta had a bit of a problem with that years ago....cant remember the fix tho...dont think a new one will help its nowt to worry about tho..are the pipes all ok no hoes or splits ect
Been driving it loads last few days and it all seems fine
Ah well ill get GS motor sport to check it when it goes in
Ill keep you posted just incase some one else gets this prob
Filthyrichie funny you should say about pipes because when we fitted oil breather kit the vent pipe that goes under car had knocked off the pipe to the solanoid canister the side that runs behind ABS block thing
It was off for days and i spotted it but the car still drove ok
it was a few weeks later i noticed the clicking
