*****Anyone know of a good garage******
Re: *****Anyone know of a good garage******
Originally Posted by Danny-p
Anyone know of a good garage round the north west that i can get my small turbo escoss running problems sorted once and for all and wont get ripped off or my car getting wrongly diagnosed. Need cosworth trined person or someone compitent. Tried (MSD new chip+ Bleed valve+30psi = blown head gasket )
car symptons
Stalling every now and then
blue smoke out of exhaust (just stopped)
Misfiring
low oil pressure
slow as f**k
Thanks if any one can help
car symptons
Misfiring
low oil pressure
slow as f**k
Ahhhh, your Carolines (kennys ex missus) Nephew arent you?
Your car came here with serious running problems (suspected head gasket problems and you required it confirmed) the chip fitted to the car was a GGR chip that was faulty for some reason so to run it without hitting the boost limiter we advised fitting another chip which YOU agreed you wanted so we fitted one.
When the chip issue was resolved and we testd rove, we determined that the head gasket was indeed faulty and advised you of this, along with header tank cap failure and the amal valve was actually missing.
You had teh option of fitting a new one at £60 or a cheaper option was a bleed valve (Lockable 3 port) You chose the cheaper option so we fitted it and set the boost to a max of 18, as all Stg 1 escort T28s run. (where did you get your 30+psi reading from then?)
You were then given the bill and told your headgasket is failing as YOU originally suspected and we advise you dont use the engine hard until it is repaired for obvious reasons.
I recall you (or was it your dad?) were also upset that you wanted to pay only half the bill and have the other half on credit and Kenny refused you even though your semi related, so thats put your nose out of joint i guess? Sorry for you...
That sound's as little more like events as I remember them, but it was a while ago so forgive me any small inaccuracies......
Another MSD bodge job
When will people learn not to use these cowboys
Fucking hell Stu, you can choose your friends but you cant choose your customers eh mate?
Absolutely priceless the massive difference between how he presented it and what actually happened, how the fuck can ANY business manage to keep a good reputation when jokers like this are running round bad mouthing them when they have done asbolutely nothing but the correct thing?
How events can differ from one mouth to the next
It would be much easier if people actually stated the whole facts in these cases
wheelwizardrefurbs
24-09-2015 08:35 PM
