escort mk1 cossie estate 2.1
spec etc
heres the spec,ht built 2.1 engine,200 block,long studded,gp 4 head gasket,t38.63 turbo,-31,bailey turbo damper,big wing sump,world cup cross member,greys injectors,ported head,rad tec rad and rs500 intercooler,bailey breather,verners x2,sfs hoses apart from 1 got to hot,3 bar map senser,group 4 coil,chipped ecu(level 6),comp fuel inj collector pot in rear, nos 50bhp shot
comp bias pedal box
t5 standard gearbox
hydraulic clutch
1 piece pop,atlas axle 48",tranx gp n diff with atlas side gears,quaife atlas 770mm/18t halfshafts,quaife gp 4 atlas flange,
9" rear drum brakes.
wilwood front brake calipers with drilled and grooved discs,braided brake lines. adjustable tca.
bilstein coil overs(front), rear mk5 van gas skocks.single leaf spings decambered.lowered 2 1/2 inch
_________________
394.4 bhp with 376 lbs of torque power is up now ..
not bad for a old estate!
comp bias pedal box
t5 standard gearbox
hydraulic clutch
_________________
Last edited by jaymk1cossieestate2.1; 02-07-2010 at 10:49 PM. Reason: more things added to car
How do you find the Wilwoods? I want to stick to 13"'s on my Mex and have heard good and bad reports. Capable for the speeds the cossie brings?
I saw this drifting at Santapod last year BTW and its a lovely motor.
jay ,
what suspension you running,sounds like english and leafs and normal struts up front.does it run better on the road in this form rather than the current trend to gp4 everything.
cheers
rob v
cheers
rob v
english with tran-x with atlas side gears,fronts are 2.8 bilsteins coil overs,rear single leaf de-cambered 2" on mk5 van gas shocks.
