Plenum Spacers for YB
Old Feb 3, 2006 | 11:42 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Plenum Spacers for YB
What are your thoughts on these ?
Are they worth fitting ?
Steve.
Old Feb 4, 2006 | 12:08 AM
aduz's Avatar
aduz
my mate said it made a bit of a difference on his yb
Old Feb 4, 2006 | 07:50 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Lets have some input on these please
Steve.
Old Feb 4, 2006 | 07:51 PM
Gregs's Avatar
Gregs
what are the pro's and cons?
is there more lag but higher top end power?
Old Feb 4, 2006 | 08:41 PM
cressy's Avatar
cressy
did sum 1 say more POWER thats me sold on the idea lol
Old Feb 4, 2006 | 10:00 PM
warleydaddy's Avatar
warleydaddy
Id like to know what these are all about actually??
Pete..
Old Feb 4, 2006 | 10:18 PM
righthooker's Avatar
righthooker
me too,a mate of mine wants me to try one out ,has something to do with air flow and stuff
Old Feb 4, 2006 | 10:56 PM
luke89's Avatar
luke89
Team HOTHOT!
they increase the internal capasity so it can flow more, think the standered one will run 700odd rod has one on his and is running 900+ , sure some one will corect me if im wrong but see a post abot this not that long ago
Old Feb 5, 2006 | 12:17 AM
Alloy's Avatar
Alloy
In my opinion they are only needed if your trying to gain huge horsepower figures. They increase the capacity to allow higher volumes of air to be taken in as said. I don't think a standard plenum or even a RS500 plenum could flow 700bhp to be honest Luke, I could be wrong though.
EDIT: Do you mean a standard plenum with a spacer? If so I apologise and you're right!
Old Feb 5, 2006 | 01:30 AM
luke89's Avatar
luke89
Team HOTHOT!
alloy :im not 100% what a standard plenum could flow that was just a gustamet, i think maby more around 600 acculy , but rod has over 900bhp with his inlet and a spacer
Old Feb 5, 2006 | 07:35 AM
Graceland's Avatar
Graceland
Team HOTHOT!
if you are going for huge horsepower figures, it makes sence to buy one of Mike Rainbums sweedish plenums - a pinch at only 300 quid or thereabouts
Old Feb 5, 2006 | 07:50 AM
Gracey, i think that Rods 700bhp or so off gas proves that a spacer on a normal plenum can work.
Dont forget lads that if you do make a change to the plenum like spacing it or swapping it to another type in order to improve flow then you need your ECU remapped afterwards.
Old Feb 5, 2006 | 08:22 AM
There you go 16mm Spacer. If you want to make Mike R richer buy one of his plenums, but this set-up will give you the Power no doubts.
Rod
ps. Not as sexy looking as something Swedish .
Old Feb 5, 2006 | 08:28 AM
RS500+ Spacer can & does in my application.
Old Feb 5, 2006 | 08:39 AM
double post
Old Feb 5, 2006 | 08:43 AM
Jay,'s Avatar
Jay,
Sponsor
here rod as your neil lost somthing in ur engine bay lmao
oh did u dort that belt out by the way mate
cheers jay
Old Feb 5, 2006 | 12:57 PM
warleydaddy
SO on a stg 3 engine,are they worth it??
Whats the general answer..
Pete..
Old Feb 5, 2006 | 02:01 PM
Jay,'s Avatar
Jay,
Sponsor
pete ones goin on mine and it wont 400 at the spec its at think if anything it will help towards reliability
cheers jay
Old Feb 5, 2006 | 02:21 PM
Pete..
No need, and if you do fit one you will need a remap, you cant use the same chip and expect it to still fuel perfectly with difference airflow charecteristics,
Old Feb 5, 2006 | 02:29 PM
They would in theory improve drivability...hence why the RS500 had the bigger inlet left on for the road car to help combat the shit setup!
IMO if you are running a stage 3 off the shelf map from a reputable dealer then you would have enuff safety margin to soak up the spacer But of course always CHECK with an AFR setup!
Old Feb 5, 2006 | 02:35 PM
warleydaddy
Cars not mapped yet...
Got greys and L8 to go on it.. BUt if im GOING ot put stuff on it,i want the right stuff,before i get it all mapped up,so i was just asking if there worth it or not??
Pete...
Old Feb 5, 2006 | 02:48 PM
MAD Ade's Avatar
MAD Ade
Pete..
Pete, IMHO, unless you're using over 2bar of boost I don't think you'll gain very much for how much it will cost.
Ade.
Old Feb 5, 2006 | 03:18 PM
foreigneRS's Avatar
foreigneRS
Testing the future
how? a smaller volume behind the throttle would improve driveability by having a quicker throttle response
Old Feb 5, 2006 | 03:43 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
not worth fitting imho.standard inlets are ok to 450 bhp,then its the throttle body and the bend that restrict flow,and the spacer wont improve that.different on the rs500 with 8 injectors.
Old Feb 5, 2006 | 04:19 PM
How do they improve driveability phil?
Surely its going to do the opposite and make it less responsive to small throttle openings at lower rpm, and thats what most people consider driveability?
Old Feb 5, 2006 | 04:48 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
eh?
reason the RS500 road cars had the inlet was same reason it had all the differences from a normal 3dr, GrpA Homologation rules
Better drivability due to more BHP/torque....so back to back at the same boost pressure a genuine RS500 should be better driver off boost than a similar engine running a std 4x4 plenum....due to increase in airflow thus improving the power
Old Feb 5, 2006 | 04:54 PM
Alloy's Avatar
Alloy
I know Rod mate, I meant without a spacer.
Old Feb 5, 2006 | 04:58 PM
In tears
Old Feb 5, 2006 | 05:01 PM
Why have you just looked in the mirror?
Old Feb 5, 2006 | 05:04 PM
No phil i just read your post about drivability
Picture what happens when you open the throttle a little bit, what happens?
Picture it with different volume plenums, which do you think is going to respon first, the one filling the smaller plenum with boost before it gets to th engine, or the one filling the larger volume?
come on phil, i know you can do it?
Old Feb 5, 2006 | 05:09 PM
Chip....as i pointed out the two similar cars would have 2 different throttle sizes
Old Feb 5, 2006 | 05:11 PM
Alloy's Avatar
Alloy
Rod, what is the copper pipe for by the rocker cover?
Old Feb 5, 2006 | 05:13 PM
that copper pipe is for det cans mate.
Old Feb 5, 2006 | 05:14 PM
And that is relevant to a debate on plenum sizes on the same engine in which way phil?
You have TOTALLY got it arse about face, im amazed sometimes still after all this time at how badly you miss the basics
Old Feb 5, 2006 | 05:15 PM
Alloy's Avatar
Alloy
Sorry, what is det can's chip?
Old Feb 5, 2006 | 05:18 PM
....just like the ESCOS EEC4....bigger plenum/elbow and throttle body with small turbo ='s the best drivability there is in YB terms.
Chip all you out for is glory against ME...how sad
Old Feb 5, 2006 | 05:21 PM
Alloy's Avatar
Alloy
Mate I don't know much about the technical side of thing's with car's, and I'm in no place to get involved with this discussion, but you keep bringing irrelevant thing's into the argument, chip mentioned the plenum and nothing else, so why are you refering to throttle bodies and turbo's etc?
Old Feb 5, 2006 | 05:22 PM
Phil whats glory got to do with it?
Im just trying to help the lad get accurate information about his engine, not rattle on about complete different engines altogether.
Now, one more time, on his engine, with his turbo and his throttle size, which engine is going to respon better to a slight throttle opening, the one filling hte big plenum before the engine sees the boost, or the one filling the small one?
Surely there are enough clues in that question to work out how wrong you were?
Old Feb 5, 2006 | 05:23 PM
Replica's Avatar
Replica
eec4 engine has smaller turbo and head ports so will have better response anyway right ?
