Plenum Spacers for YB
Old Feb 5, 2006 | 05:23 PM
  #41
Originally Posted by Alloy
Originally Posted by Bosch-Man
....just like the ESCOS EEC4....bigger plenum/elbow and throttle body with small turbo ='s the best drivability there is in YB terms.
Chip all you out for is glory against ME...how sad
Mate I don't know much about the technical side of thing's with car's, and I'm in no place to get involved with this discussion, but you keep bringing irrelevant thing's into the argument, chip mentioned the plenum and nothing else, so why are you refering to throttle bodies and turbo's etc?
Cause when phil is wrong, he is never clever enough to spot it, so normally tries to change the subject to something totally different so no one notices what a monumentally bad bit of advice he just gave someone
Old Feb 5, 2006 | 05:26 PM
  #42
Sorry, what is det can's chip?
Det cans are what Rods tuner (mark shead) uses to listen out for detonation within the engine when he is setting up the fuelling and more specifically the timing on Rods engine.
They also use them as a safety check when doing the topspeed runs, hence they get used so often the copper bit lives on the car ready for them!
Old Feb 5, 2006 | 05:27 PM
  #43
I apologise i was looking at a bigger picture...and Chip still didnt fit
Sorry.
Old Feb 5, 2006 | 05:28 PM
  #44
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Sorry.
  #45
Bad advice?Where?In this thread...i quoted IN THEORY it improves drivability i didnt say it WOULD....MANY MANY variables to drivability
Old Feb 5, 2006 | 05:29 PM
  #46
Alloy's Avatar
Alloy
Sorry for being a pest chip, but incase you didn't see:
I'm assuming it's something to do with detonation, but I'd like to know the technical side of it and what hardware is involved...only if you don't mind explaining of course.
  #47
Sorry.
You werent looking at the bigger picture correctly though phil.
The larger plenum, in whatever picture, is NEVER there for driveability. its there for top end power.
Old Feb 5, 2006 | 05:30 PM
  #48
Alloy's Avatar
Alloy
Ah, nevermind, seen your reply above. Thank's mate.
Old Feb 5, 2006 | 05:31 PM
  #49
What theory, the theory where it takes less time to fill a bigger space?
Fooking hell Phil, STOP AND THINK!
Its such a basic principle!
Old Feb 5, 2006 | 05:32 PM
  #50
Martin-Hadland
phil, i am going to attach a large dustbin to my engine with a single throttle on the other end and use that as a plenum ....in your experiance do you think this will improve drivability?
Old Feb 5, 2006 | 05:34 PM
  #51
or if not in experience, just in theory phil
  #52
...but there is a bigger throttle so it counteracts it surely?..For the same throttle position one has a bigger opening.
A bit like a well used women...to which you are not familiar
Old Feb 5, 2006 | 05:36 PM
  #53
warleydaddy's Avatar
warleydaddy
GOD I LOVE IT!!!!!!!!!!!
Pete...
  #54
Alloy's Avatar
Alloy
Other people using your woman is nothing to be proud of.
Old Feb 5, 2006 | 05:42 PM
  #55
It is,as my women is a 10 stone Rottie
Old Feb 5, 2006 | 05:43 PM
  #56
And probably has a better grasp of physics than you phil
Old Feb 5, 2006 | 05:47 PM
  #57
Physics?
.....let me mention T4 at the same boost pressure as a T34.....they do NOT create the same amount of air....so a bigger opening will fill up the plenum quicker than the smaller opening can...thats PHYSICS.
Old Feb 5, 2006 | 05:51 PM
  #58
Physics?
Thats all nice simple basic stuff, but how is it relevant to the thread starter changing the plenum size on his engine?
Have you STILL not grasped that a larger plenum will reduce driveability?
Or have you grasped that but dont like admitting you are completely wrong so are trying to change the subject still?
Got to be one reason or the other you are chatting such shit, its either cause you cant work out the real answer, or cause you have but now realise what a tool you made of yourself by not being able to grasp it sooner without me and martin explaining it.
Old Feb 5, 2006 | 05:52 PM
  #59
Stavros's Avatar
Stavros
DEYTUKURJERBS
jesus wept
Old Feb 5, 2006 | 05:53 PM
  #60
boXXer's Avatar
boXXer
GASH!
uh oh.....
Old Feb 5, 2006 | 05:56 PM
  #61
Butch.'s Avatar
Butch.
welcome to the wonderful world of passion ford
  #62
You and Martin ...Pal you aint in that chaps league
I quoted in theory...if not being one dimensional....its not like anyone just puts a plenum spacer on a std Cossie with no other factors is it?
BUT if your being one dimensional like Chip...then it will make drivability slightly worse...even though you never really asked that more power advantages....so a one dimension chip style answer would be....would not make a blind bit of difference if you are ONLY doin that mod
Old Feb 5, 2006 | 06:02 PM
  #63
Phil, so are you saying that if he fits:
a larger plenum
a larger throttle
and a larger turbo
It will then be more driveable at low rpm and part throttle?
if so
But just for the record, as you still dont seem to grasp it, no matter what size throttle he has on there, it STILL going to be a disadvantage to driveablity to use a larger plenum.
If you had two engines with a larger throttle size and one had the smaller plenum that would respond better too, not just if you did it on 2 engines with smaller throttle sizes.
There is NOTHING one dimensional about it at all, its always the case!
Old Feb 5, 2006 | 06:08 PM
  #64
I love this place
Although not like the old days when i could have a thousand users arguing the toss Not as many stupid people around now i guess
Old Feb 5, 2006 | 06:09 PM
  #65
Replica's Avatar
Replica
Old Feb 5, 2006 | 06:12 PM
  #66
I love this place
Have you STILL not worked it out?
How do you manage to type with that level of inteligence, let along compicated things like drive?
Old Feb 5, 2006 | 06:14 PM
  #67
I love this place
Because of stupid people like YOU.
Old Feb 5, 2006 | 06:17 PM
  #68
You dont realise how GOOD it is to be known as dumb....no one asks me anything,no one beleives what i type...so no one expects anything from me...so i can just go about DIYing MY own vehicles to my standards...although if judging by my persona on here i am shocked my cars actually run
Old Feb 5, 2006 | 06:19 PM
  #69
...for a very intelligent bloke Chip you dont half look stupid arguing with a known idiot
..and that concludes todays Laural and Hardy show...tune in again real soon.
Old Feb 5, 2006 | 06:21 PM
  #70
Replica's Avatar
Replica
so did we establish any facts about spacers then
Old Feb 5, 2006 | 06:25 PM
  #71
Replica i am sure Chip will explain as he likes talking to us idiots
Old Feb 5, 2006 | 06:28 PM
  #72
righthooker's Avatar
righthooker
another interesting read gone to shit
Old Feb 5, 2006 | 07:00 PM
  #73
Thats one way Martin i was going to fit a 9" thick spacer to improve mine.
Surely Phil is on drugs .
Old Feb 5, 2006 | 07:17 PM
  #74
Alg1k's Avatar
Alg1k
God and i thought these spacers were to stop surge
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
