long brake pedal.....?
Old Feb 3, 2006 | 11:22 PM
think twinks's Avatar
think twinks
Default long brake pedal.....?
hi got s1 pick up and i've replaced the brakes.... got cosy rear dics brakes, and willwood 4 pot front brakes, and now the pedal allmost go to the floor, i've changed the master, and new pads all round and blead brakes, still no joy help.....
Old Feb 3, 2006 | 11:56 PM
SafeChav's Avatar
SafeChav
Hello mate
oh dear welcome to the world of brake conversions on RST's. First things first, what position are your calipers mounted at, and in which direction are the bleed nipples facing on the rear calipers?
Old Feb 4, 2006 | 08:28 AM
HORNETS7's Avatar
HORNETS7
AS ABOVE WHEN U BLEED THE REAR BRAKES U HAVE TO BLEED THEM WHILST THE CALIPER IS NOT FIXED !
SO U CAN PULL THE CALIPER ROUND TO THE TOP SO THE NIPPLE FACES UPWARDS THATS HOW ITS EXPELS THE AIR GIVE IT A TRY IT WILL BE THAT!!
YOU'LL NOT BE GETTING THE AIR OUT OF THE RAR CALIPRS!
Old Feb 4, 2006 | 09:14 AM
Dave Henshall's Avatar
Dave Henshall
also depends on teh size of the mater cylinder which is sized initially to move enough fluid to move the 2 std pistons on teh fron andn teh 2 tiny slave cylinder in teh rear hubs - once you increase the amount of fluid needed to apply the brakes by adding bigger brakes with bigger pistons and caliopers (more aparent on the back) you will find that brake pedel travel is greatly increased as yuo have to move more fluid to make the brakes come on - you may need a bigger master cylinder...
Old Feb 4, 2006 | 12:54 PM
SafeChav's Avatar
SafeChav
Originally Posted by Dave Henshall
also depends on the size of the mater cylinder which is sized initially to move enough fluid to move the 2 std pistons on the fron andn the 2 tiny slave cylinder in the rear hubs - once you increase the amount of fluid needed to apply the brakes by adding bigger brakes with bigger pistons and caliopers (more aparent on the back) you will find that brake pedel travel is greatly increased as yuo have to move more fluid to make the brakes come on - you may need a bigger master cylinder...
BINGO!!! You hit the nail on the head (where were you when i needed you )
When i had air in mine my pedal would hit the floor and the brakes would barely work, once bled the pedal had a fair old travel but did get firm. MOT centres can fail on excessive pedal travel though. Mine was ok, but to be honest the brakes feel no better, if not worse than they were, a bigger master cylinder HAS to be fitted IMO if your going to do the brakes. What size is your master cylinder currently?
Old Feb 4, 2006 | 02:00 PM
think twinks
hi i've used a presure pleader on the brakes to get the air out. the rear capilers r mounted on the back with the nipple at the top. but i thought after all that the master was to small... has any fitted a different servo/master ian p.s how do u put pic on this cheers
Old Feb 4, 2006 | 05:29 PM
SafeChav's Avatar
SafeChav
Hello mate
i used a pressure bleeder for mine too, but if the nipples arent in the right place u will still get air pockets in them. Can u take a picture of the rear caliper for me? I'm currently looking into doing my master cylinder. On your master cyliner there should be a number printed on the side, being a series 1 im guessing 22, maybe 23.
Pictures, on the main forum index page in the Frequently asked questions section there is a very good how-to on pictures.
mjonathan24
Oct 29, 2015 10:39 PM
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
focus2351
Sep 9, 2015 09:33 PM
