RS 500 intercoolers.
Old Feb 3, 2006 | 04:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Default RS 500 intercoolers.
Just fitted mine today,do they generally give you a small rise in boost pressure,and on average how much more power ?
Old Feb 3, 2006 | 04:31 PM
rapidcossie's Avatar
rapidcossie
i got another 30 horse from fitting my cooler, but that also let me run another couple of psi.
the increase in power is from the raised boost pressure.
the cooler just makes it the charge temp lower in turn letting you run more boost
Old Feb 3, 2006 | 04:41 PM
KSA-Cossie's Avatar
KSA-Cossie
Cheers euan roll on spring time till i go to ava .
Old Feb 3, 2006 | 04:48 PM
rapidcossie
what turbo is on it??
Old Feb 3, 2006 | 04:54 PM
KSA-Cossie's Avatar
KSA-Cossie
Just a standard one i think but im after a t34.
Old Feb 3, 2006 | 05:03 PM
rapidcossie
cool!
get a t34 with 63 housing and you'll be jamming!
300ATW is a possiblity with a good stage three engine and that turbo
300 ATW is fecking quick!
Old Feb 3, 2006 | 05:16 PM
KSA-Cossie's Avatar
KSA-Cossie
Whats that at the fly ? Be nicer with 400 at the wheels like yours !!!!!
Old Feb 3, 2006 | 05:22 PM
rapidcossie
300 atw wheels is probs about 340 ish at the fly??
400 atw is usless in this weather cant get grip at all!
Old Feb 3, 2006 | 05:24 PM
rapidcossie
to measure your hp AVA will run your car in third.
mines was ran in 4th due to it wheels spinning on the rollers in 3rd.
if we could get grip in 3rd mine would prob do closer to 420 ATW
Old Feb 3, 2006 | 05:27 PM
KSA-Cossie's Avatar
KSA-Cossie
420 atw sooooooooooooooooperb .
Old Feb 3, 2006 | 05:28 PM
rapidcossie
that is estimated power....
as are all rolling roads figs
would love to get the engine out and put it on a dyno for a true figure
Old Feb 3, 2006 | 05:30 PM
KSA-Cossie's Avatar
KSA-Cossie
Well hopefully ava can get me 330 atw or more.
Old Feb 3, 2006 | 05:51 PM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
Default Re: RS 500 intercoolers.
Depends which one you fit!
Old Feb 3, 2006 | 05:54 PM
rapidcossie
no way they can get that power on standard compression, cams etc.
300 atw wheels is best to expect before ripping the engine to bits
would also need to change the greens for blues or maybe even greys
Old Feb 3, 2006 | 06:00 PM
KSA-Cossie's Avatar
KSA-Cossie
Doh! meant 300 not 330.
Old Feb 3, 2006 | 06:04 PM
rapidcossie
yeah would be nice to see 300.
thats defo the limit for greens.
mines had the comp ratio lowered abit but apart from that was a standard engine.
It made 287 atw, running a t34 with a 55 back
Old Feb 3, 2006 | 06:07 PM
foreigneRS's Avatar
foreigneRS
Testing the future
pmsl at ATW power figures are all estimated
if that's the case, why bother putting it on the rollers to 'measure' it?
Old Feb 3, 2006 | 06:11 PM
rapidcossie
most turbo cars never make the exact same power figs twice.
things like air temps, charge temps make massive differences.
unless its engine out and on a dyno is always an estimate in my eyes
Old Feb 3, 2006 | 06:12 PM
KSA-Cossie's Avatar
KSA-Cossie
No m8,what he said was all rolling road figures are estimates and he'd rather put it on an engine dyno to check it.
Old Feb 3, 2006 | 06:16 PM
Fiecos Dan's Avatar
Fiecos Dan
a std internal engine, except H/G can make 360bhp @ fly on blues and t34 surely,
and on a larger turbo, say t4 and greys will see 420@fly.
Old Feb 3, 2006 | 06:50 PM
stonehavencossie's Avatar
stonehavencossie
Got my pro alloy cooler fitted yesterday to.
Car does seem nippier and smoother . Surely not 30bhp gain though, Thought it was more like 10 ?
Where do you have your Dump Valve (if u have one). Mine was coming out of the small outlet on the ford cooler but the new pro one doesnt have that.
Old Feb 3, 2006 | 06:55 PM
rapidcossie
I can only discuss power on AVA rollers as thats all i have experence in using.
300 at wheels on AVA rollers would prob be about 350 flyon a rollers down south.
Old Feb 3, 2006 | 06:56 PM
rapidcossie
dump valve re-located to cold side of engine.
you either need a new inlet hose with dump valve take off or you can get a fitting kit from halfords.
is a metal t piece that means you have cut the hose and fit this in the middle.
KSA-Cossie's Avatar
KSA-Cossie
I don't run a dump valve m8,but have blanked it off on the cold side hose.
Old Feb 3, 2006 | 07:12 PM
stonehavencossie
Ill swap hoses lol. My cold side doesnt have a dv take off.
You know where i could get one ? Cant afford a full boost kit this month after buying the cooler
Old Feb 3, 2006 | 07:14 PM
KSA-Cossie's Avatar
KSA-Cossie
If it's a blue samco you have then it's a deal ! Check out e bay m8 many a bargain hose wise on there.
Old Feb 3, 2006 | 07:15 PM
stonehavencossie
Ah never noticed ur reply rapid. Dont fancy using the fitting kit would prefer a proper hose. Once i do get one is it simply a case of cutting the vacum pipe smaller ?
Old Feb 3, 2006 | 07:19 PM
stonehavencossie
Have checked ebay. nothing at the moment. will keep lookin. its just a standard hose ive got at the mo.
Ive still got the dump valve connected to the vacum pipe but going into nothing (just cable tied up). Will this do any harm or should i blank of the vacum end until i sort a new hose ?
Old Feb 3, 2006 | 07:22 PM
KSA-Cossie's Avatar
KSA-Cossie
Personally i would blank off the vacum end.
Old Feb 3, 2006 | 07:24 PM
stonehavencossie
Without sounding stupid how do i do that lol
Old Feb 3, 2006 | 07:30 PM
KSA-Cossie's Avatar
KSA-Cossie
Either fit a proper blank or do as you've done with the hose already.
Old Feb 3, 2006 | 10:00 PM
stonehavencossie
Right roose motorsport do individual hoses just need to make sure i get the right one
Is the one i need intercooler to standard sierra cosworth throttle body ?
And, do i need 70mm or 76mm ?
Thet have a page advert in performance ford
Old Feb 4, 2006 | 05:51 AM
KSA-Cossie's Avatar
KSA-Cossie
Yeah m8 intercooler to throttle body .
I thought it was more like 63mm.
Old Feb 4, 2006 | 07:32 AM
stonehavencossie
says 70 or 76 in advert. It will be the same as the standard ford size as there both the same.
Old Feb 4, 2006 | 08:23 AM
big_wig_074's Avatar
big_wig_074
my car made 300 atw once and was estimated at 371 at the flywheel. on a 2wd saff btw but that was on greys 63 t34 etc
Old Feb 4, 2006 | 12:35 PM
Fiecos Dan's Avatar
Fiecos Dan
I'm quoting engine dyno figures, not RR guess work figure @ fly as you quote.
Aint Avo RR a home built set up? not a dig, just a question as that wot i got told.
in fact a good std rs500 engine set up on greys make 430bhp@ fly with no problems in the 80's early 90's.
Old Feb 4, 2006 | 12:39 PM
rapidcossie
AVA did design and build thier rolling road...
It is regarded as one of the best in britain
Old Feb 4, 2006 | 12:40 PM
Fiecos Dan's Avatar
Fiecos Dan
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Cos500
Sep 26, 2015 01:11 PM
cos elle
Sep 25, 2015 09:52 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
