Quick Question...How do i run with NO Boost at all???
Old Jul 21, 2004 | 02:22 PM
CosRush's Avatar
CosRush
Default Quick Question...How do i run with NO Boost at all???
Is it simply a case of locking the Wastegate fully open???
Ive got a severe Misfire, but running it off load on Axle stands its fine through to redline.
I want to roadtest it now with no boost...
Is it possible?
Old Jul 21, 2004 | 02:25 PM
Oranoco's Avatar
Oranoco
Disconnect the actuator rod so the wastegate opens at the slightest hint of boost but if I rememebr correctly it'll just fart and won't rev past about 3k.
Old Jul 21, 2004 | 02:26 PM
DaveEscos's Avatar
DaveEscos
extend the actuator rod as far as it takes to reduce the boost to virtually zero
or stuff a sock in the inlet of the turbo!
Old Jul 21, 2004 | 02:30 PM
Jim Galbally's Avatar
Jim Galbally
just unclip the thing... there should be an e-clip to undo then itll pop off the wastegate (the actuator rod that is)
the wastegate will stay open itself as the gases will push it open... no need to hold it open manually...
youll be lucky to see 1-2psi even all the way up to the redline like that...
ps the car will be VERY slow
Old Jul 21, 2004 | 02:40 PM
CosRush's Avatar
CosRush
Thanks fella's.
I had posted in the Technical Section about the problem ive got, and received lots of things to try. One of which was the question 'Does it do it off boost'
And it doesn't.... so thought i'd see what happened if i ran it up (Axle stands) to get to the problem rev area, then if it started misfiring i could then start checking various things...
But it didn't misfire...
Thanks fella's i'll have to try a road test now...
Old Jul 21, 2004 | 02:54 PM
Jim Galbally
when its on axle stands its under no load, so unlikely to do bugger all
Old Jul 21, 2004 | 02:59 PM
Tim's Avatar
Tim
If you do what divey jim says when you connect the rod backup the penny will have carboned up and will not seal right ,jim strikes again fpmsl
CosRush's Avatar
CosRush
Exactly...
Thats why ive done it. No Load... and no Misfire....
Thats narrowed it down a little bit...
If you're confused see my post in Technical...
Old Jul 21, 2004 | 03:07 PM
Jim Galbally
tim, please explain how this will cause long term damage after being run like that shortly for testing purposes...
Old Jul 21, 2004 | 03:52 PM
Dave Henshall's Avatar
Dave Henshall
does sound like plugs - check the gap and have a spare set of plug to try to to prove a point...
Old Jul 21, 2004 | 03:54 PM
AlexF's Avatar
AlexF
Tim...
that theory would mean every time the waste gate opens it would carbon up!!!!
They are not that critical on tollerences!
alex
Old Jul 21, 2004 | 04:52 PM
richm's Avatar
richm
eh??????
so what do you suppose happens when the wastegate opens normally? no carbon? The tiny bit that may accumulate in that time will soon rub off with a bit of preload on the gate...
Old Jul 21, 2004 | 05:04 PM
MadMac's Avatar
MadMac
or how about this; take the turbo off?
Ok maybe not such a good idea
Old Jul 21, 2004 | 05:16 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
What about disconnecting the amal valve. Take the clip off the top of it and u'll have no voltage to it.
Might be wrong, but it wont do any harm
Old Jul 21, 2004 | 06:13 PM
richm's Avatar
richm
this will reduce the max boost, but depending on the preload on the actuator, boost will still be made.
Disconnecting the actuator for the duration of the test is the easiest and most predictable way..
s1turboman
Aug 29, 2015 04:27 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Toe Knee
Aug 23, 2015 08:31 AM
Neatrags
Aug 16, 2015 07:57 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
