e30 bmw sites or can u help with my bmw cabriolet?
anyone know of any e30 bmw sites online?
I found one called e30zone but its down at the mo and not working any others around?
Took my hardtop off my 325i cabriolet and theres 2 pins that u slip the rear of the roof where the glass is that are kinda linked to the rear heated rear screen.
I had a mess about with these 2 stud things to adjust there heights so they were the same on both sides as one was abit taller than the other. The roof has 2 holes that slip over these lond stud things that stick out. Anyway i messed about with it and put roof back on.
I went to check my heated rear screen, an see if it's still working and when i pressed the button in dash it popped a fuse in the. So, replaced fuse tried again and popped it again.
Any ideas whats up with it now and why its doing this?
cheers peeps
cheers peeps
