Tarox 6 pots and Poly bushes
Old Jan 31, 2006 | 06:07 PM
S1rst's Avatar
S1rst
Default Tarox 6 pots and Poly bushes
I have Tarox 6 pots with 40 groove discs on my car, and they seem to squeak quite a bit. A few people ive spoken too about it have said thats just how they are????????
Is there any truth in this or is there a way I can get rid of it as its starting to annoy me now.
Also, I have poly bushes all round and they seem a bit squeaky too. Its coming from the front when going over speed bumps (maybe top mounts?). Is this normal or could they be too tight/loose?????
Thanks in advance, Rich.
Old Feb 1, 2006 | 05:28 PM
S1rst's Avatar
S1rst
Any ideas on this, Thanks.
Old Feb 1, 2006 | 09:59 PM
big-dirty-dog's Avatar
big-dirty-dog
hmmm me too have tarox 6 pots and poly bushs no problems here brakes a kinda newish at the mo done about 300 miles with um on but no squeaks etc........hope i havent got um coming either
Old Feb 2, 2006 | 11:28 AM
dojj's Avatar
dojj
Resident Wrestling Legend
did you grease the bushes before you put them in?
thats why they may be squeaking
as for the discs, the groves pointing in one direction squeak less than they do the other
other than that, it might be just the pads you are using that is causing lots more dust than normall
Old Feb 2, 2006 | 07:24 PM
PAT@SUPREMES's Avatar
PAT@SUPREMES
I DONT KNOW IF IT WILL HELP U, I HAVNT GOT THE SAME SET UP AS U.BUT IVE BEEN TOLD 2 USE WURTH ANTI-SQUEL SPRAY ON MINE.ITS MEANT 2 STOP THE PADS FROM SQUEAKING.HOPE IT HELPS
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
