How much oil does the RST gearbox hold ?
Jul 21, 2004 | 10:33 AM
As above
Is it 2.9L ?
Jul 21, 2004 | 10:37 AM
I believe it's nearer 4! At least I think I remember putting 4l in my S2 box which was dry and it didn't overflow!
HTH
Dave
Jul 21, 2004 | 10:40 AM
yea i think its arround about 4L too
Jul 21, 2004 | 10:45 AM
and get the smallest bottles as well its easier to use
Jul 21, 2004 | 10:52 AM
I always use a funnel on the end of a short length of clean hose pipe.
Less spil and mess that way.
Jul 21, 2004 | 10:57 AM
it holds 3.5 litres exactly thats what the haynes manual says
Jul 21, 2004 | 10:59 AM
3.7 should be enough
Jul 21, 2004 | 11:00 AM
It's 3.1 Litres. If you have managed to get more in, thats because you had the car jacked up when you filled it!!
I use an Oil Syringe to pump the oil in as that gets it into all the nooks and crannies. Make sure the car is flat when you do it.
Jul 21, 2004 | 12:16 PM
Just to add to this (maybe burnie can help) which gearbox oil is the best to use?
Paul Ripley (FF2.1zetec) gave me a half full bottle of Morris gearbox oil which he said he was quoted as the best around?
Ideas
Jason
Jul 21, 2004 | 12:26 PM
semi synthetic 80w-90 will be fine.. IIRC they do a 'special' grade which is specifically for gearboxes with LSD's.. i 'think' its labeled as 80w-90 LS
Phil
Jul 21, 2004 | 06:27 PM
daft question-where do you fill the box up from
JK12
33
Apr 26, 2021 12:09 PM
Billy_RS
Sep 13, 2015 04:17 PM
Adam Graham
Sep 6, 2015 06:04 AM
gingeRS
Sep 4, 2015 06:29 PM
hopper350
Sep 4, 2015 12:53 AM
