Cossie help...Fuel pump voltage?
Old Jan 29, 2006 | 07:06 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Default Cossie help...Fuel pump voltage?
swapped over my fuel pumps today to see if that was the cause of the splutter and loss of fuel pressure once the car had warmed up. Second fuel pump works fine but does exactly the same as the first. Soon as car is hot it intermittently loses all fuel pressure. No particular revs or throttle. Fuel pump then becomes noisier than normal too.
anyways using a multimeter my pal Rob sat in the boot while i was tramping on to see what the voltage was across the fuel pump relay. he said from pin 85 to earth?
he was a bit surprised at the results, the voltage climbs from first turning it over to around 17volts. voltage DOESNT drop when car splutters and loses fuel pressure. now how does it go above battery voltage? and the power to the relay comes from the ecu?
is this right or wtf is goin on?
surely my car doesnt have TWO faulty pumps?
help this is drivin us nuts!
chop
ps car goes REALLY well before fault occurs. tonight was first dry spin ive had since buying the car in august!
Old Jan 29, 2006 | 07:18 PM
Simon Day's Avatar
Simon Day
What voltage do you get at the actual pump when you turn the car over? I found that I was getting 10.8 volts on my escos..... I don't think you should see 17 volts when its running??? The max voltage you should see is the max your alternator puts out to the battery - about 14.5volts - but this can vary....
Old Jan 29, 2006 | 07:21 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
aye exactly what we thought!!!! well i shit you not its 17v! thats taken across the fuel pump relay which Robin says is whats across the pump.
battery voltage is normal 13/13.5volts!
dont know why the voltage goes so high but could this be screwing up the pump?!
aaaaaagggghhhhhhh
Old Jan 29, 2006 | 07:35 PM
Simon Day's Avatar
Simon Day
I would get it checked I don't think the pump should be seeing 17volts!! Damo V for example wired a direct supply from his battery to the pump (including relay & fuse) to make sure he had a reliable 12 volts..... I think my pump is getting about 10-11 volts (a bit low ) - so I am thinking of doing the same as Damo..... Yours is a bit high though...
Old Jan 29, 2006 | 07:43 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
yup very strange! where the hell is the power coming from
Old Jan 30, 2006 | 07:39 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
bump
Old Jan 30, 2006 | 07:41 AM
Neil S's Avatar
Neil S
Chop, you need to measure the voltage AT the pump, not the relay.
There will be some drop along the wiring to the boot, the inertia switch etc.
Re the meter, I suggest operator error, if you're sure that the battery voltage isn't 17V too?
Neil.
Old Jan 30, 2006 | 07:49 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
neil
battery voltage is as i said above 13/13.5v or whatever. I dont suspect user error either tbh. Robin will be along here later with his input
still we're fucking stumped
Old Jan 30, 2006 | 10:37 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
any more advice?
Stu perhaps?
Old Jan 30, 2006 | 10:48 AM
Neil S's Avatar
Neil S
Chop, have you considered it may be the regulator causing the problem?
Neil.
Old Jan 30, 2006 | 10:53 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Neil.
do you mean fuel pressure regulator?
Mike r suggested regulator on the alternator thats why i asked. Car holds high fuel pressure for while after car is turned off so didnt think it was the FPR.
Old Jan 30, 2006 | 10:58 AM
Neil S's Avatar
Neil S
OK, fair enough
Just a thought
Old Jan 30, 2006 | 11:01 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
do you agree with me tho? fuel reg should be ok if pressure remains when car is off?
Old Jan 30, 2006 | 11:20 AM
Matt's Avatar
Matt
std reg as in the sig pic sleeve ? one one of them you know whats?
voltage seen at pump should rise with rpm as far as i can remember. dingo defo tested mine whilst i was sat revving car up (stationary)
Old Jan 30, 2006 | 11:24 AM
Matt's Avatar
Matt
have asked him for you like the fucking star i am
Old Jan 30, 2006 | 11:26 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
standard regulator yes
i tried msn'in dingbat but no reply. ask him what voltage you should see at the fuel pump relay. pin 85 to earth.
cheers
chop
Old Jan 30, 2006 | 12:08 PM
Matt's Avatar
Matt
"min is 13.3 volts under load.....
He needs to re-wire it from the battery and check the earth's
also what voltage is at the ecu..."
Old Jan 30, 2006 | 12:35 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
thanks mcbell
Old Jan 30, 2006 | 12:50 PM
Neil S's Avatar
Neil S
Chop, this is how I did my pump:
Clicky
There is probably an easier way, but this retains all the standard wiring runs, inertia switch etc, but still has less attenuation
Neil.
Old Jan 30, 2006 | 02:04 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
decided to book it into auto electricians for wednesday. Guy reckons it might be a battery/alternator problem because nothing else could boost the voltage to 17v at fuel relay.
gonna get them to rewire the circuit as neil has done too
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
