l8 ecu or something to run my rs500?
my engine should be in my rs500 this week! hopefully.
i was looking to go with l8 ecu and 4 grey injectors or get an ecu to run 8 greens.i have both sets of injectors but need either a l8 or something to run 8 injectors.
what set up would people reccomend for my car and does anyone know where i can get the relevant ecu-i missed an ecu that had been modded to super 8 spec on ebay a while back.
the engine going in used to be in my sapphire which was running 8 greens on a wrc manifold with p8 management and a t38 turbo.
what sort of power can i expect from either set up-the 4 greys or 8 greens along with the t4?
the engine is 200 long studded block,knife edged crank,low comp,multi layer head gasket,head ported to wrc spec,bd10 cams,bronze guides.it was over 400 bhp in the sapphire.......
all info/reccomendations will be greatly received
thanks jay
thanks jay
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
