Lack of oil pressure (another problem)
Old Jan 29, 2006 | 11:05 AM
davidnormanuk's Avatar
davidnormanuk
Default Lack of oil pressure (another problem)
Driving home from work last weekend and noticed on my oil pressure gauge that it was low. Checked the pressure relief valve which was fine. Checked the pickup pipe to make sure it ws clear so decided to replace the pump for a new one. Put that on started the car up and the oil pressure was still down by 20psi using the same make and grade oil as previous when I was getting 60psi from cold then 40 psi when warm. I have been told next to make sure none of the crack bearings have rotated and tio check and measure everything. Just wondered if there is anything I shold be looking out for?
Any help on this wold be appreciated.
Dave
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
StephTell
Sep 2, 2015 06:31 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
