got a clifford concept 600 need help
Old Jan 28, 2006 | 08:36 PM
abdr500's Avatar
abdr500
Default got a clifford concept 600 need help
i got a clifford concept 600 i belive and it has the engine remot start but i forgot how to use it can any 1 help
Old Jan 28, 2006 | 08:41 PM
dave cos4x4's Avatar
dave cos4x4
there is a help post put up by Stu for clifford alarms,try a search.
Old Jan 28, 2006 | 09:26 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Re: got a clifford concept 600 need help
As far as I know these can be setup a number of different ways, so advice from anyone may not be much help.
Much better to go and see a pro who will be able to figure out exactly how the alarm has been setup.
BTW, were you aware that remote start invalidated the cat 1 status of the alarm , it's an add-on, rather than part of the alarm itself and not seen as "safe" by the thatcham / insurance peeps.
Old Jan 28, 2006 | 09:41 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
I had intellistart...
if its G5 then while the engine is running press the CLIFFORD button on the fob twice then press the ** button...
if when you take keys out engine still runs obviously its worked and it'l die when you activate alarm. Press the * button to remotely start engine after that.
hope this helped
Old Jan 29, 2006 | 02:23 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
the users guide might help
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
Tank Mike
Sep 14, 2015 03:56 PM
