help needed escort cossie problem.......
Old Jan 28, 2006 | 11:32 AM
B13 JUS's Avatar
B13 JUS
Default help needed escort cossie problem.......
my brakes have gone hard my hardbrake light is stopping on but they were all ok when i parked it up 4 winter.......
all i've done is changed a wheel and charged the battery.......
also when i turn the ignition on the abs pump not pumping up???
any ideas????
Old Jan 28, 2006 | 11:36 AM
The DIVA's Avatar
The DIVA
ABS pump motor has seized or the pressure switch is faulty mate.....
All late 4x4 pumps are the same,you should be able to pick one up for buttons....
Old Jan 28, 2006 | 11:37 AM
The DIVA's Avatar
The DIVA
Check the main ABS fuse as well,I`ve not had one go yet but you never know...
Old Jan 28, 2006 | 11:41 AM
B13 JUS's Avatar
B13 JUS
i've checked all fuses they r ok
if the pump was seized how will i un seize it????
Old Jan 28, 2006 | 12:10 PM
B13 JUS's Avatar
B13 JUS
where abouts is the pressure switch mate?????
Old Jan 28, 2006 | 12:18 PM
xr4x4rs's Avatar
xr4x4rs
do you run a heatshield?
if not you could of possibly melted a wire or some for the ans
just go through everything on the pump to the connectors
Old Jan 28, 2006 | 12:28 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Try changing the accumulator on the ABS pump - big spherical black thing - it unscrews - use something like an oil filter wrench on it!!!
Old Jan 28, 2006 | 03:46 PM
B13 JUS's Avatar
B13 JUS
no i don't run a heat shield and have checked the wire's they r ok
i've tryed changing the pressure switch (not that)
i'll try the accumulater 2morrow
anything else it can be??????
Old Jan 28, 2006 | 03:55 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
dont know about escorts but had the same prob on my saph, turned out to be the fuse under the dash next to the relay
Old Jan 28, 2006 | 04:13 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
for god sake don';t undo that sphere until it's depressuised!!!! u'll kill yrself!!!
did u take the battrey out to charge it?
check u've re attached the pump feed back up to the + terminal.
Old Jan 28, 2006 | 05:18 PM
B13 JUS's Avatar
B13 JUS
how will i know if it's depressured???
yeah i took the battery of 2 charge it..... do u know which wire it is mate???
Old Jan 28, 2006 | 06:03 PM
T38Mat's Avatar
T38Mat
I had a problem with the escort a year back with the fuel pump not coming on and it turned out to be the fuse box thing under the steering wheel. I was told they just lose tracks due to old age and need replacing! Old cars eh!
Good luck mate.
Old Jan 29, 2006 | 03:26 PM
B13 JUS's Avatar
B13 JUS
the pump on the abs was broke i changed in but still not working is there any other fuses or relays other that on the fuse box?????
also where is the accumulater at????
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
kosienutter
31
Aug 22, 2015 09:55 AM
stickyslick
14
Aug 10, 2015 06:27 PM
col93saphcos
Aug 7, 2015 03:21 PM
